Capt Lou
NJ, USA Status: offline
Jaka: I have asked the same question and have only receieved positive answers that the RX/servos can handle it. I have a Wild Hare 300 Extra powered by a 50cc Desert Aircraft gas engine. I use a JR flight pack consisting of a JR 921 RX, and five JR 8611A and two 821 digital servos and do not use a voltage regulator. They are all rated for 6 volts. I have been told that when a 6 volt nicad/nimh (which this flight pack is rated for) comes off the charger they produce the same voltage as the A123 battery pack and will not harm the RX or servos. I use one A123 pack for the ignition and two packs for the RX/servos. Also, I checked with Desert Aircraft and they told me that their ignition can handle an A123 battery pack without a voltage regulator. I have had my plane flying for about a month, have 45 flights on it, and have had no issues with the flight pack. I like the A123 technology because it charges fast and is easy to use. I use a CellPro 4s charger which tells me how much capacity has been consumed and replaced. However, I asked the same question of Futaba's technical people here in the U.S. and got conflicting answers. Its RCU forum moderator gave me a text book answer that with respect to the Futaba servos, they are only rated 6 volts and it recommends that you use a regulator but their RX's have a built in regulator, while their technical staff has told some flyers that it is OK not to use a regulator. The result for me was that after 25 years of using Futaba, I now swithched to JR.
