RE: GYRO and the AXE CP
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> Helimax >> RE: GYRO and the AXE CP
Page: <<   < prev  1 [2] 3 4 5 6 7 8   next >   >>
Login
RE: GYRO and the AXE CP - 2/21/2007 12:13:11 AM
quickster47
Status: offline
That is correct. The new ESC you used also has a BEC built in and if you connect it to the receiver without removing the middle wire on the connector, the +v, you will be supplying the receiver +v from two different sources.
Carl
(in reply to sammy64)
       Post #: 26
RE: GYRO and the AXE - 2/23/2007 3:44:12 AM
bryon261
Status: offline
i'm installing the 240 gyro in my axe. you said the heli starts to spin when batteries get low, can you keep control of your heli long enough to land ? i'm still using nimh batt.'s i know i will have to upgrade, i only get about 4 minutes of flight and i'm only hovering in my garage. live in michigan, will have to wait for better weather. how much longer flights do you get with lipo's?
       Post #: 27
RE: GYRO and the AXE CP - 2/23/2007 11:05:48 AM
sammy64
Status: offline
Yes, if you are using what Helimax says to use as a ESC and you run the battery's down to 2.7V the ESC cuts power to the motor and starts to spin. There are other ESC that don't do that and i have a link to them. really need to get some liPo battery's. really makes the heli fun to fly now with a gyro
(in reply to bryon261)
       Post #: 28
RE: GYRO and the AXE CP - 2/23/2007 9:50:04 PM
bryon261
Status: offline
if you could give me the link to a better esc that would be great. i could send back the esc helimax suggested.. would i connect it up the same way?
       Post #: 29
RE: GYRO and the AXE CP - 2/24/2007 8:47:34 PM
AirforceRcks
Status: offline
just a question but for us people that dont hae huge budgets would this gyro work, maybe?
the one at the bottom.
http://hobby-lobby.com/falconparts.htm
the botttom one
< Message edited by AirforceRcks -- 2/24/2007 11:00:25 PM >
       Post #: 30
RE: GYRO and the AXE CP - 2/25/2007 4:34:43 AM
DC Havoc
Status: offline
I would just like too say that being a newbie to the Axe CP, that I have only just begun too start flying this thread and fourm has helped alot. I just installed the speed control and gyro upgrades in my CP. Thamks guys for all the info.
< Message edited by DC Havoc -- 2/25/2007 4:36:36 AM >
       Post #: 31
RE: GYRO and the AXE CP - 2/25/2007 12:19:48 PM
sammy64
Status: offline
Yes that gyro will work.. i used what helimax used but i have also started to change different parts out like the ESC .. find one that does not cut out .. makes it a lot safer
(in reply to AirforceRcks)
       Post #: 32
RE: GYRO and the AXE CP - 2/25/2007 12:22:41 PM
sammy64
Status: offline
its is a lot easyer to fly ... i think this is the best MOD yet for the AXE CP .. but i`m sure someone will find more to MOD on it soon .. next step is a new radio .. also makes a huge differnce
(in reply to DC Havoc)
       Post #: 33
RE: GYRO and the AXE CP - 2/25/2007 8:31:34 PM
FlyinAmos
Status: offline
Has anybody had trouble with the axe cp drifting to the left? I can some what hover it, but it allways goes to the left. Your help in this mater would be most helpful. flyin amos
       Post #: 34
RE: GYRO and the AXE CP - 2/25/2007 8:43:58 PM
Heliko
Status: offline
It's called tail rotor drift and it's normal. The thrust from the T/R pushes the heli to the left so you need a little right cyclic to counteract it.
_____________________________
"Gravity is a harsh mistress." The Tick
(in reply to FlyinAmos)
       Post #: 35
RE: GYRO and the AXE CP - 2/26/2007 8:11:31 PM
jrsaoe
Status: offline
i just installed the 240 gyro and test flew it. The 240 works great, by far the best upgrade you can do for this heli. Tail stays solid, although i am still fine tuning the gain. But as said before with the electrifly brushed esc the tail motor stops once the battery hit the limit voltage. I thought that removing the red wire disconnected the BEC? I test flew with the stock battery, and got about 4 minutes of flight, lipo is a must. Helidirect has some good ones for cheap. But the spinning of the heli is a fatal occurance, in normal flight this would have caused death and destruction. So anyone have any ideas on a better esc that does not cut the motor?
(in reply to Heliko)
       Post #: 36
RE: GYRO and the AXE CP - 2/27/2007 12:17:38 AM
Heliko
Status: offline
Hey jrsaoe you might be able to find something here that will work for you.
(in reply to jrsaoe)
       Post #: 37
RE: GYRO and the AXE CP - 2/27/2007 10:14:59 PM
AirforceRcks
Status: offline
If you reread the gyro installation on the helimax site it show how to disable the BEC. not sure if that is the problem or not.
i could just be an idiot repeating something tho.
       Post #: 38
RE: GYRO and the AXE CP - 2/28/2007 1:28:38 AM
Heliko
Status: offline
I believe the speed control senses cut-off voltage from the battery input wires. The BEC just powers the Rx. Some speed controls have programmable cut-offs beyond that there's not much that can be done about it. A li-po should help alot.
< Message edited by Heliko -- 2/28/2007 1:29:44 AM >
       Post #: 39
RE: GYRO and the AXE CP - 3/4/2007 4:59:25 PM
VBDave
Status: offline
Ok, I've now seen people saying you can use the 401 Gyro's just Plug-n-Play... but I haven't seen any actual instructions or people wanting to share the connections.. Is this true? and can anyone provide docs for us gyro NewBs ? lol
       Post #: 40
RE: GYRO and the AXE CP - 3/4/2007 8:51:45 PM
sammy64
P
