123Splat
Joined: 4/27/2007 From: Austin, TX, USA Status: offline
Jim, No real problem in going for a cheaper HH gyro, just make sure that the specs say that it is tempreture compensated. After I smashed my $119 GY240, I tried another brand price at around $30-$40. Worked for about 20 seconds and then started drifting. Shutdown to try to figure what's going on, can't find anything. start 'er up again, lift off, everything's good. Then after 20-30 seconds, she starts drifting again. If it was balance or setup, I wouldn't have gotten 20-30 seconds of good flight response, same logic for battery on sebsequent runs without changing the battery. That only leaves the electronics, which still point to cheap gyro. Went back to Futaba, didn't research pricing though (paid another $119 to Tower). Now everything's back to normal(?). Gyro works like a charm. Even holds pretty well in a light wind. Now I'm thinking about adding weight under the main rotor to dull response even further and compensate for my 'spaz thumbs'. Good flying, Splat
_____________________________
It's not the takeoff or the flying, it's the landing and repairing, so I can takeoff and fly again...
