RE: GYRO and the AXE CP
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> Helimax >> RE: GYRO and the AXE CP
Page: <<   < prev  1 2 3 4 5 6 [7]
Login
RE: GYRO and the AXE CP - 4/10/2008 9:48:31 PM
BigTruckDriver
Status: offline
quote:
ORIGINAL: Shadow99
With the Electric Tail Motor, the GY240 Gyro will hold the tail (better than the Rate gyro), but not Rock Solid. No matter where you set the gain the tail tended to wiggle (you could hear the motor oscillate in RPM). Then you also have to worry about the tail ESC shutting down when it reachs its AUTO-CUTOFF voltage, especially if you use the C-12 ESC, that was one of my biggest issues. You be flying fine, then without warning the tail motor would shut off, causing the AXE CP to spin uncontrollably.
Once I switched to the BDT (Belt-Driven Tail), performance became ROCK SOLID, no matter how hard I push the tail, it holds position. Lately I've been doing hard piro's, 360 tail spins, and when I stop the tail it HOLDS! So well in fact, I noticed the tail boom flexing under load, so I added some boom struts to stiffen things up (more modified Align parts).
Rick
So for the STOCK AXE CP the gy240,c-12 esc ,and the BDT should bring the axe up to speed with some of the higher end helis? Thats about 250 dollars right? I know its a training Heli but really thats all I need. Will this gyro work with brushless motors later down the line?
< Message edited by BigTruckDriver -- 4/10/2008 9:53:40 PM >
_____________________________
If it isn't broken,adjust it till it is.
(in reply to Shadow99)
       Post #: 151
RE: GYRO and the AXE CP - 4/10/2008 10:55:56 PM
BigTruckDriver
Status: offline
Will this 40 gyro work with the axe cp?
http://www.freestyle-hobby.com/catalog/product_info.php?cPath=30&products_id=250&osCsid=c60dbffb9b935fd1a4d5c44f99bda665
(in reply to BigTruckDriver)
       Post #: 152
RE: GYRO and the AXE CP - 4/11/2008 3:51:19 AM
blvdbuzzard
Status: offline
I just put a 240 in my AXE and used the stock 3 in 1. It is an easy install. It holds the tail a lot better. There is just a hint of drag. Sort of an over shot then back to the correct position. The gyro cost is almost the same as the total for the AXE.
Dru.
       Post #: 153
RE: GYRO and the AXE CP - 4/11/2008 4:32:09 AM
Rotor13B
Status: offline
I don't look at it so much as being expensive, More like an investment. You can move that gyro to another heli and it will work just as well. I've used cheaper gyros and while they will work you get what you pay for. In my opinion the gyro is not where you want to cheap out.
(in reply to blvdbuzzard)
       Post #: 154
RE: GYRO and the AXE CP - 4/11/2008 4:46:50 AM
Rotor13B
Status: offline
quote:
ORIGINAL: BigTruckDriver
quote:
ORIGINAL: Shadow99
Rick
The Axe is not a trainer heli, It just happens to come with something that most heli's do not and that would be the training gear. Usually that is seperate cost to purchase with most helis. .30 sized helis don't come with it yet people put the gear on it protect the heli while learning to hover. If you want something to learn orientation on I would suggest a coaxial heli to learn on. Too often I see someone jump right into cp helis get frustrated and sell it because they can't fly it.
If you get the belt tail mod and the GY240 you'll be good to go. If cost is a concern I would learn on the stock unit as hovering doesn't require alot tail movement anyways. Since the gyro plugs into your receiver it doesn't matter what your power source is, Brushed brushless etc. You only need the C-12 if you want to hook up a gyro to the motor driven tail and even that is optional to a certain extent with some gyros. Not all gyros will work properly without the tail esc so choose wisely.
       Post #: 155
RE: GYRO and the AXE CP - 4/16/2008 8:47:30 PM
samscasa
Status: offline
Anyone have any suggestions for calming the tail wag on an AXE-CPL? I (and one of the local heli experts) have adjusted the 3 in 1 from one end to the other, replaced the tail motor and the tail is still ultra sensitive esp to right yaw input. The tail motor zings up and down rapidly and it is a handful just getting the thing to hover. I have mostly worked the left-right bias pot and the gyro gain pot with some improvement but not much. I almost wish I had a dual-rate switch to soften the tail up some.
Thanks for any help/suggestions!
       Post #: 156
RE: GYRO and the AXE CP - 4/17/2008 4:11:09 PM
PilotLight
Status: offline
You might as well try the top screw adjustment.
(in reply to samscasa)
       Post #: 157
RE: GYRO and the AXE CP - 4/17/2008 7:22:43 PM
benlevy3
Status: offline
Hey guys. I posted to this thread a long time ago. Since then I have moved up to a T-Rex450. I am also flying a T-Rex600N and just recently a T-Rex500.
Anyway, not to rain on anyone's parade, but if you are going to put $200+ in to an AxeCP, would it not make more sense to just go ahead an buy a Blade 400. I have never seen one fly, but from the review I have read, it seems like a great deal for $460.
By the way, I have an AxeCP for sale if anyone wants. W/ 2 LiPos (no charger) and a bunch of other stuff for $90.
(in reply to PilotLight)
       Post #: 158
RE: GYRO and the AXE CP - 4/17/2008 9:05:46 PM
Rotor13B
Status: offline
What does it matter if you crash a blade 400 or an Axe Cp with $460 dollars invested in it? You still have 460 bucks worth of junk when you crash. Alot of people complain because they've dumped 100, 200, Even 300 or more into there Axe and then get all bent out of shape and say " I could've had a trex for that kind of money". What they aren't accounting for is your still going to crash while learning and now instead of starting with a 200 dollar heli now they have a 500 dollar heli and putting that same kind of money in parts. Now your approaching a $1000 bucks and could've had a .30 sized heli with radio and support equipment. It's not so important how you spend the money, It's what you get out of it that's important. As the old saying goes, "Hindsight is 20\20.
(in reply to benlevy3)
       Post #: 159
RE: GYRO and the AXE CP - 4/17/2008 9:28:21 PM
Shadow99
Status: offline
I couldn't have said it better myself, R13b!
My MX300 (was an AXE CP), has about an additional $300-450 dollars in ad-ons (not including the DX7), but I have one hell of a heli, to LEARN & CRASH with, rather than CRASH my new T-rex 500, which is twice as big & expensive when it comes to parts!
Rick
Click to see fullsize image.
Click for fullsize
Click for fullsize
"Growing older is MANDATORY... Growing up is OPTIONAL!"
(in reply to Rotor13B)
       Post #: 160
RE: GYRO and the AXE CP - 4/17/2008 9:35:02 PM
benlevy3
Status: offline
Actually Rotor13B has a GREAT point. The initial price of the Heli is not as big a deal as the repair cost.
With that in mind, I have found that T-Rex parts are 1/2 OR LESS then the Axe CP parts. I don't know about the Blade 400.
If you don't believe me, go and do some price comparisons.
I don't really care what anyone flys. I am not a T-Rex fan boy. The point is that you are enjoying the hobby. If you have a $2,000 Axe CP, and you are happy with it, then all the power to you.
Happy Flying!
       Post #: 161
RE: GYRO and the AXE CP - 4/17/2008 11:58:49 PM
BigTruckDriver
Status: offline
quote:
ORIGINAL: benlevy3
Pics go a long way thats a good deal.
       Post #: 162
RE: GYRO and the AXE CP - 4/18/2008 2:27:27 PM
benlevy3
Status: offline
Thanks for the comment. The Axe CP is sold. Actually, when I packed it up, there was a lot more stuff then I thought. Anyway, I am happy and hopefully the buyer will be too.
       Post #: 163
RE: GYRO and the AXE CP - 4/21/2008 9:07:43 PM
BigTruckDriver
Status: offline
I have hooked up the gyro and esc and tested. The tail motor kept twitching ,on off on off, any ideas. other times the tail motor would run with no power up to motor just sitting on the ground. dont know I will get more time this afternoon to check it out.
(in reply to sammy64)
       Post #: 164
RE: GYRO and the AXE CP - 4/21/2008 10:09:24 PM
n5iln
