Engine Test bench
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Questions and Answers >> Engine Test bench
Page: [1]
Login
Engine Test bench - 2/16/2007 4:42:43 PM
zscheidt
Status: offline
Hello,
I'm using the cold weekend to build a test bench for some engines i have in the basement. These are somewhat small (.42 two stroke and .82 four stroke) and I wondered if anyone had ideas or designs to help me.
My plan is to fix a small block of some sort to cradle and mount the engine with a spot for a servo behind and a place to rubber band a small removable fuel tank behind as well. I want to then be able to take the block and attach it to a standard stanley vice table that is portable (that way I can take it outside, lock the mount into the table, and fire up the engine).
Has anyone put together such a contraption or have any pictures or instructions? Anything I should think about or plan for ahead of time? I want to make sure it is stable and yet still able to move inside and out without too much trouble.
Zach
       Post #: 1
RE: Engine Test bench - 2/16/2007 4:44:51 PM
Flying freak
Status: offline
you might want to make the fuel tank adjustable in high ...
(in reply to zscheidt)
       Post #: 2
RE: Engine Test bench - 2/16/2007 5:14:14 PM
Kevlar
Status: offline
Here's one I 'borrowed' some ideas from...its off RCU, do a search, you'll find quite a bit more.
...and like stated...make the tank height adjustable...you could use blocks or stand-offs.
Click to see fullsize image.
Click for fullsize
(in reply to Flying freak)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.297RCU1
