Presence
Joined: 1/25/2007 From: Toronto, ON, CANADA Status: offline
boys, that screw u indicated in the picture is not the second gear adjustment screw. thats the screw to tighten to the cup once its in there. what u'll need to adjust is the screw with the spring (in the picture) that u turn tight then 2.5 - 3 turns out..so what u do is loosen that other screw first (the green one in the picture), then tighten the adjustment screw, then turn 2.5 turns out. now put it in the other cup...THEN tighten the other set screw, so it fits tightly on the cup. then put the rest of it together, and try it out. u'll need to play around with the shift screw, but u can do that from under the chassis. i had the same problem, and my 2nd gear works like a charm now. Hey jon, my fail safe is 100% now...i had to also tweak that. that venom smart temp fail safe is too advanced man. hahaha. peace!!!
_____________________________
***Co-Founding Member of RS4 Nation***
