RE: Cool Power Fuel Question ??
Tower Hobbies
Logged in as Guest
  Printable Version
NIB O.S. Engines O.S. .91 SZ-H PS-Hyper - RTF
Seller:  mkranitz
Details:   $339.00   |  10/6/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: Cool Power Fuel Question ??
Page: <<   < prev  1 2 [3] 4   next >   >>
Login
RE: Cool Power Fuel Question ?? - 2/21/2007 6:04:28 PM
KC36330
Status: offline
quote:
ORIGINAL: Sport_Pilot
Watch the all alcohol funny cars and dragsters run. Notice they don't have huge flames coming out of the exhaust pipes. Because, guess what, the methanol burns faster than the nitro.
amazing how that is exactly what has been stated many times and you argue, the Nitro slows the burn rate when mixed, do you in all honesty believe that the glow fuel we use when burned in the engine, burns the methanol and the nitro separately??? when you MIX the two, the combination burns slower, again i apologize that you can't seam to see the forest for the trees being all in the way.
kc
(in reply to Sport_Pilot)
       Post #: 51
RE: Cool Power Fuel Question ?? - 2/21/2007 6:28:56 PM
Don M.
Status: offline
quote:
ORIGINAL: jaka
Hi!
.....And all the guy asked for was why Morgan fuels had so strange pecentage labeling....
No answer yet as I could see...
_____________________________
I can only please 2 people every day and #2 just left.
(in reply to jaka)
       Post #: 52
RE: Cool Power Fuel Question ?? - 2/21/2007 6:53:49 PM
Sport_Pilot
Status: offline
That is not what you said, you said that the nitro slows the burn rate of the methanol down. When you mix fuels you usually end up with an average between the two and not take on the characteristics of one of them. The fuel burns slower because the nitro burns slower, the methanol is burning at its own rate. The introduction of nitro speeds up the flame front which causes detonation, but at the same time its residual continues to burn, so the fuel has charatistics of both fast burning and slow burning fuel.
This is about the best article I have seen on nitro, at least as it is used in drag racing.
< Message edited by Sport_Pilot -- 2/21/2007 6:55:25 PM >
“I Saw Elvis at 1000 Feet” John Force
(in reply to KC36330)
       Post #: 53
RE: Cool Power Fuel Question ?? - 2/21/2007 7:46:04 PM
KC36330
Status: offline
when you mix nitromethane and methonol to make glow fuel, the resulting mixture burns OVERALL at a slower rate and at a cooler temperture. the methonol isn't burning at it's normal rate and leaving behind the nitro at its slower burning rate, the mixture is as a whole burning slower then a straight methonol mix. it's just like the mixing of lead and tin to make solder, lead melts at 621º F, tin melts at 450º F, yet a 60/40 mix of the two results in a melting temp of 370º F, far lower then either of the originals, they don't melt at their own representative melting points, just like the mix of nitro and methonol don't burn at their original prespective burn rates.
kc
       Post #: 54
RE: Cool Power Fuel Question ?? - 2/21/2007 8:06:48 PM
Sport_Pilot
Status: offline
quote:
ORIGINAL: KC36330
Actually I think this is very likely. In fact most likely the nitro if anything is speeding up the burn rate of the methanol. Nitro doesn't exactly burn slower, it actually burns quicker or at least the flame front, but it also burns longer. Maybe a better way to explain it is it burns like a log which has been soaked in kerosene?
kc
This is the interaction of the molecules, or molecules which has a weaker bond to another element
       Post #: 55
RE: Cool Power Fuel Question ?? - 2/21/2007 8:31:18 PM
KC36330
Status: offline
methanol has a flash point of 67º F, Nitromethane 110º F so how would you come to the conclusion that the nitro would have a quicker flame front?
kc
       Post #: 56
RE: Cool Power Fuel Question ?? - 2/21/2007 8:54:16 PM
Sport_Pilot
Status: offline
Flash point and flame front speed are not the same thing. One is evaporation and the other is combustion. Also I believe nitro has a flash point below 100, or else it would not be labeled flamable. It is like saying that diesel doen't burn as hot because it has a higher flash point. Coal has a very high flash point but it burns very hot. Especially when ground into a powder.
I believe the flame front speed is mentioned in that Wikipedia article.
       Post #: 57
RE: Cool Power Fuel Question ?? - 2/21/2007 9:19:07 PM
KC36330
Status: offline
.............. Also I believe nitro has a flash point below 100, or else it would not be labeled flamable.
as mentioned many times by many people in many different threads about what you debate it's always what you believe not what you know to be factual. the flash point of Nitromethane IS 110º F and is listed with hazards of flammable (with a rating of 3)
kc
       Post #: 58
RE: Cool Power Fuel Question ?? - 2/21/2007 9:34:27 PM
Sport_Pilot
Status: offline
When I say, "I believe", it usually means I am recalling from memory and not that I know it not to be factual. I do not make stuff up, but sometime my memory fails me. It is actually 35 degrees centigrade and if over 100 degrees it would have a rating of flamability rating of 2 not 3. If you were so certain why did you not post a link.
http://en.wikipedia.org/wiki/Nitromethane
http://en.wikipedia.org/wiki/NFPA_704
       Post #: 59
RE: Cool Power Fuel Question ?? - 2/21/2007 9:43:30 PM
KC36330
Status: offline
are you so hell bent that you are right that you don't even bother to read the link you posted............it clearly shows a flammability rating of 3 on the Wikipidia link.
also from the MSDS on Nitromethane
quote:
ORIGINAL: http://www.sciencelab.com/xMSDS-Nitromethane-9927374
Flash Points: CLOSED CUP: 35°C (95°F). OPEN CUP: 44.44°C (112°F)
HMIS (U.S.A.):
p. 5
Health Hazard: 1
Fire Hazard: 3
Reactivity: 3
Personal Protection: j
National Fire Protection Association (U.S.A.):
Health: 1
Flammability: 3
Reactivity: 4
also you have to compensate for changes in barometric pressure as this plays a bit with the numbers.
kc
< Message edited by KC36330 -- 2/21/2007 9:45:49 PM >
       Post #: 60
RE: Cool Power Fuel Question ?? - 2/21/2007 9:56:16 PM
Sport_Pilot
Status: offline
If you would read my lips instead of trying to dig a deeper hole you would know that I said it is rated at 3 and has a flashpoint of 95 degrees. You said it had a flashpoint of 110 degrees if it did it would have a rating of 2 not the 3 it is rated at.
       Post #: 61
RE: Cool Power Fuel Question ?? - 2/21/2007 9:57:39 PM
majortom-RCU
Status: offline
Thunderous applause for that volley! I'm a little drunk at the moment.
       Post #: 62
RE: Cool Power Fuel Question ?? - 2/21/2007 10:02:23 PM
KC36330
Status: offline
a 3 is Liquids and solids that can be ignited under almost all ambient conditions.
a 2 is Must be moderately heated or exposed to relatively high temperature before ignition can occur.
110° isn't moderately heated nor a relatively high temperature. lots of places in this world have ambient temps of 110° F NITRO IS FLAMMABLE
kc
< Message edited by KC36330 -- 2/21/2007 10:04:07 PM >
       Post #: 63
RE: Cool Power Fuel Question ?? - 2/22/2007 12:34:40 AM
hihihi
Status: offline
hi i need help im new i need to know what type of nitro fuel the magnum nx monster truck takes i need to know asap plz.i hope you help me
(in reply to TimC)
       Post #: 64
RE: Cool Power Fuel Question ?? - 2/22/2007 12:37:16 AM
hihihi
Status: offline
hobbsy will you help me find out what type of nitro fuel is needed to run the magnum nx monster truck i need help bad.
(in reply to
