Brushable epoxy
Tower Hobbies
Logged in as Guest
  Printable Version
F-16C 1/6 LARGE JetLegend (Now available in THUNDERBIRD ..(We offer Building & C - ARF
Seller:  FlyingboyD
Details:   $2,960.00   |  8/16/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Kit Building >> Kit Manufacturer Direct Support Forum >> Brushable epoxy
Page: [1]
Login
Brushable epoxy - 2/18/2007 4:37:50 PM
FoeFoe
Status: offline
Hi, Can any of you gents out there advise me on how to thin epoxy i.e. to make it brushable to fuel proof an engine compartment for example ? I used rubbing alcohol with 5 minute epoxy and ended up with a goowy horrible result. Any advise appreciated.Thank you.
       Post #: 1
RE: Brushable epoxy - 2/18/2007 4:41:21 PM
saramos
Status: offline
Rubbing alcohol has too much water in it. You want to use denatured alcohol or acetone to thin epoxy. You might want to use 30 minute epoxy too. Whichever you use, mix the epoxy first, then add the thinner.
Scott
(in reply to FoeFoe)
       Post #: 2
RE: Brushable epoxy - 2/25/2007 2:33:35 PM
FoeFoe
Status: offline
Thank you Scott wiil do. PS will Nail polish remover work or do I need to get some industrial quality acetone ???
(in reply to saramos)
       Post #: 3
RE: Brushable epoxy - 2/26/2007 4:29:20 PM
TheOldGuy
Status: offline
I just put the bottles in the microwave for 30 seconds or less and it turns to water. It will thicken up as it cools but depending on how cold it is in your workshop you can get the job done before it gets too thick.
       Post #: 4
RE: Brushable epoxy - 2/26/2007 4:58:52 PM
ir
Status: offline
Nail polish remover will not be a good substitute, it has other additives. I have used denatured alcohol and acetone. I prefer the latter, IMO it mixs more evenly especially if you are using faster drying epoxy.
If possible stay away from 5 mins epoxy. Adding acetone does not add that much time before it cures.
edited for spelling.
< Message edited by ir -- 2/26/2007 5:00:49 PM >
(in reply to TheOldGuy)
       Post #: 5
RE: Brushable epoxy - 3/3/2007 11:45:13 PM
mred33
Status: offline
Try some 20 min. Finish-Cure epoxy. It is brushable right out of the bottle and doesn't need to be mixed with anything. It's thin enough to brush and strong enough to hold like regular epoxy. You can also mix something like West System 403 microfibers with it to thicken it up like regular glue if you really need to. Works great.
Ed
_____________________________
SOME PEOPLE ARE LIKE SLINKIES. NOT REALLY GOOD FOR ANYTHING, BUT THEY BRING A SMILE TO YOUR FACE WHEN PUSHED DOWN THE STAIRS
(in reply to ir)
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.375RCU1
