what kind of craft is this???
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Unusual R/C >> what kind of craft is this???
Page: [1] 2   next >   >>
Login
what kind of craft is this??? - 2/19/2007 6:49:18 AM
mahogany dreams
Status: offline
www.hodgeshobbies.com/images/P7290027.JPG i figured this would fit in the unusual r/c section since you dont really see these everyday!!!! anybody know what it is/if it flies?
       Post #: 1
RE: what kind of craft is this??? - 2/19/2007 7:47:14 AM
lundy
Status: offline
It is a Omni-Directional Lifting aircraft .
Disigned by Joe Deloevila ,Build by Len Sabato Sr
In the early 1970 an Aeronautical Engeneer by the name of Joe Deloevila
began designing an urban transport aircraft that would take off vertically and
that transition to forward flight .
This was the first of several working models ,this exampel was designed
and build to prove that the design could produce lift .
On the second attempt the aircraft did hover.
Later models would have achieved forward flight.
This example is on display at the AMA Model aircraft Museum in Muncie Indiana .
And Donated by Paul Rudolph to the AMA Museum .
,Jules
(in reply to mahogany dreams)
       Post #: 2
RE: what kind of craft is this??? - 2/19/2007 10:42:55 AM
mahogany dreams
Status: offline
thank you for the reply, and the history!! thats very interesting!!! any more info on that?
(in reply to lundy)
       Post #: 3
RE: what kind of craft is this??? - 2/20/2007 1:57:53 AM
TopThumbs
Status: offline
I thougth it was a 27% scale X-31 Thresher
my bad
_____________________________
Support bacteria, it's the only culture some people have
       Post #: 4
RE: what kind of craft is this??? - 2/22/2007 9:01:38 PM
T.W.
Status: online
Jules: I have a facsination for unusual RC models and find the picture of this one very interesting indeed. But I can't for the life of me understand how the sytem produces lift, let alone how it could achieve omni-directional maneuverability . . . . but I really would kike to know how it works. I've searched- and browsed-around but have been unable to learn any more about it and wondered if you have more information which you would like to pass on here - or perhaps you know of a website where more details are available?
Tony
(in reply to TopThumbs)
       Post #: 5
RE: what kind of craft is this??? - 2/23/2007 12:52:48 AM
Quicksilver1
Status: offline
from looking at the pic and mind you never building an rc plane or plane.......I think I know how it works. I presume you as I did, thought the rotating airfoils would cancel eachother out but they do not. The blades seem to have pitch control which is how the wheel can produce lift. If you look closely the blades have control arms attached. The sets of rotating foils counteract eachother as counter rotation propellers do on a boat. Which stops the aircraft from "walking." On top of all this, varying the speed of eith side would move it right of left, or you could spin the craft and do all kinds of fancy things by varying the speed of all four foil wheels. then for foward movement all I think of is that they speed the rear whel up faster then the front to pitch the craft foward, and the reverse for.......reverse.
Either this or all these latter descriptions are actually accomplished with those control rods. Neat how it uses one motor, from the appearances.
Jet Villain IV (Graupner 29mm drive 700sc motor)
v(8.0) coming soon
(in reply to T.W.)
       Post #: 6
RE: what kind of craft is this??? - 2/23/2007 9:10:39 AM
T.W.
Status: online
It looks to me as though the speed of all blades is going to be the same and dependent on the speed of the engine as I see no system to achieve different speeds, but of course it would need some way of achieving this to be controlable. Hence I asked Jules if he had more details. Yes, I did notice the push-rods. I assume these are moved by cams - but of course I could be wrong. Does anyone know where I can find some actual information on this "thing?"
Tony
(in reply to Quicksilver1)
       Post #: 7
RE: what kind of craft is this??? - 2/23/2007 9:48:48 AM
lundy
Status: offline
Four eccentric cams , one located on each of the blades controlled individual blade pitch.
At the top of the are the blades were positioned with positive pitch Producing lift , zero pitch
was set on the side , and negative pitch on the bottom.
The engines rpm controlled the rate of climb and descent.
The first time they attempted to fly the model it did not produce enough lift , so the cams where
redesigned .
Later models have achieved forward flight by adjusting each cam independently or by using
an additional engine for the forward thrust .
Tony this is all the info I have considering this craft , its from the AMA Museum.
As far I know there is no info on the web over this flying thing .
,Jules
(in reply to T.W.)
       Post #: 8
RE: what kind of craft is this??? - 2/23/2007 10:07:41 AM
T.W.
Status: online
Thanks for the extra information ,Jules. I'll write to the AAA museum to ask if they have any more details. It's a fascinating craft for sure
Tony
(in reply to lundy)
       Post #: 9
RE: what kind of craft is this??? - 2/23/2007 1:51:11 PM
lundy
Status: offline
If you are getting more information from the AMA let us know something Tony ?
I was interested in this craft the moment I saw it in the museum ,
In September we are going back there , gone make some detailed photos of it .
,Jules
Click to see fullsize image.
Click for fullsize
< Message edited by lundy -- 2/23/2007 1:53:26 PM >
(in reply to T.W.)
       Post #: 10
RE: what kind of craft is this??? - 2/23/2007 5:37:59 PM
T.W.
Status: online
Will do ,Jules . . . . and if I don't find any more info perhaps you'll be able to add to what you already said here, after your next visit to the museum? I don't see me trying to build something similar, but I "must" know how it works. A video would be great right now - if anyone's got a link
Tony
(in reply to lundy)
       Post #: 11
RE: what kind of craft is this??? - 2/28/2007 8:58:14 PM
T.W.
Status: online
Michael Smith, Director of the National Model Aviation Museum at Muncie Indiana, responded to my request for further information about this mode. Her said this: It was acquired by the museum in 2001 but unfortunately we do not have that much information on it, nor any video. Mr. Delocvila, the designer, passed away from a heart-attack not long after this example flew and Mr. Sabato, hired by Mr. Delocvila as the model builder, did not follow up with the project. Supposedly Mr. Delocvila presented information to the US Patent Office, however I have not been able to locate anything. The purpose of the completed operational model would have been to promote the concept to full-scale aviation companies. From my understanding the aircraft was originally going to an urban transport aircraft, moving people around from building to building in large cities. That being said, the model is in a "military" scheme.
This particular model, the only one built, was designed with the sole purpose of proving that the four sets of turning blades could produce lift. Each blade has a push rod connected to a cam in the center of each wheel. As was mentioned in one of the comments on the forum, the cam changes the pitch of each blade as it goes through the circle producing lift at the top. For this example a single engine turned all four sets of blades using a series of belts. When tested it was tethered. The first tests produced no lift and so Mr. Delocvila redesigned the cams. On subsequent tests the aircraft did hover. Later models were to have full control allowing the aircraft to fly forward, reverse, and side-to-side. Unfortunately we do not have any information on how this might have been achieved. Discussions have included adjusting the speed of each set of blades independently or adjusting the pitch of each set of blades independently. An additional power source located in the back of the aircraft providing forward thrust has also been mentioned based on the appearance of the model.
And there you have it guys. I wish there was more information, but I guess not . . . . unless "you" have something else to pass-on?
Tony
(in reply to T.W.)
       Post #: 12
RE: what kind of craft is this??? - 4/6/2007 9:32:59 PM
Pla
Status: offline
I want to build this thing!
Properly designed, it can have 3 rotational controls, 2 movement controls, and 1 throttle control - total 6 channels needed. Throttle can be controlled with governor, so it doesn't need to be on the stick.
This is sweet!
(in reply to T.W.)
       Post #: 13
RE: what kind of craft is this??? - 4/6/2007 11:31:35 PM
T.W.
Status: online
Go for it Pla . . . . and please be sure to report your progress here
Tony
(in reply to Pla)
       Post #: 14
RE: what kind of craft is this??? - 4/7/2007 12:49:48 AM
Pla
Status: offline
Even if I decided to build it (very small chance), how could I make the parts?
I could reuse some parts from LHS, but if I wanted custom parts (in single digit quantity) where could I order them?
(in reply to T.W.)
       Post #: 15
RE: what kind of craft is this??? - 4/8/2007 9:52:20 AM
Wild Foamy
Status: offline
get your own home workshop , a little lathe, a decent vertical mill and a pillar drill...
Wild Foamy - BMFA #158272 - Solo'd 31/7/07
(in reply to Pla)
