RE: mustang color sheme
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Painting, Detailing & Bodies >> RE: mustang color sheme
Page: <<   < prev  1 2 3 [4]
Login
RE: mustang color sheme - 2/22/2007 6:21:43 PM
The Drift King
Status: offline
on your blue car?how many centimetres between the wheels?
P.S.:i send u a new pic
< Message edited by The Drift King -- 2/22/2007 6:32:12 PM >
(in reply to rushevoross)
       Post #: 76
RE: mustang color sheme - 2/22/2007 7:17:16 PM
fugadude
Status: offline
Just give me a link to where you found it. I'm not sure if it's getting corrupted through email, these adobe files can be problematic in that way.
(in reply to The Drift King)
       Post #: 77
RE: mustang color sheme - 2/23/2007 12:53:45 PM
The Drift King
Status: offline
http://www.freewebs.com/022678700/rcsupra.htm
(in reply to fugadude)
       Post #: 78
RE: mustang color sheme - 2/23/2007 1:07:44 PM
fugadude
Status: offline
I mean to the file.
       Post #: 79
RE: mustang color sheme - 2/23/2007 1:09:53 PM
The Drift King
Status: offline
Where can I find that?
       Post #: 80
RE: mustang color sheme - 2/23/2007 2:36:47 PM
fugadude
Status: offline
Where did you get the file you sent me?
       Post #: 81
RE: mustang color sheme - 2/23/2007 4:03:10 PM
The Drift King
Status: offline
In 'my documents'. But you know what? Just take it from the site I gave you
< Message edited by The Drift King -- 2/23/2007 4:49:10 PM >
       Post #: 82
RE: mustang color sheme - 2/23/2007 8:08:04 PM
fugadude
Status: offline
Send me a link to where it is located.
       Post #: 83
RE: mustang color sheme - 2/24/2007 8:14:43 AM
The Drift King
Status: offline
       Post #: 84
RE: mustang color sheme - 2/24/2007 8:49:23 AM
fugadude
Status: offline
I need a link to the actual file. I don't feel like spending half an hour looking for it on that site. Just send me a link to the file you sent me.
       Post #: 85
RE: mustang color sheme - 2/24/2007 9:52:23 AM
The Drift King
Status: offline
If you follow my link, you will see the picture when the page is loaded!
       Post #: 86
RE: mustang color sheme - 2/24/2007 10:40:47 AM
fugadude
Status: offline
ROL
       Post #: 87
RE: mustang color sheme - 2/24/2007 11:17:43 AM
The Drift King
Status: offline
just copie the file from the site and convert it to psd. with IMAGE CONVERTER PLUS
       Post #: 88
RE: mustang color sheme - 2/24/2007 11:36:32 AM
fugadude
Status: offline
Sorry bro it doesn't work that way. Unless you have a source file for the graphics that is either vector via photoshop or a sizable raster I can't make a graphic from it. From that picture the best I could get is probably a 1/4th inch graphic. You should try to get in contact with the guy that made the graphic and see if he'll share it with you.
       Post #: 89
RE: mustang color sheme - 2/25/2007 1:28:43 PM
The Drift King
Status: offline
So source file is like: C:\\Documentsandsettings...?
       Post #: 90
RE: mustang color sheme - 2/25/2007 1:55:29 PM
The Drift King
Status: offline
you know what? Just measure the place between the two wheels of your supra and then print it out like you print out the other things.
       Post #: 91
RE: mustang color sheme - 2/25/2007 2:04:25 PM
fugadude
Status: offline
Hmm ok think of it this way. most everything you look at when printed is in the 150 - 600 dpi range. Dpi ranges are used for a variety of print viewing distances. Say if you're 5 feet away you can't see the dots on a 150dpi print. When you look at a nice magazine and you're like wow look at these pictures they're so clear most likely you're looking at an image which was printed using a higher dpi setting.
When you look at a newspaper you notice right away that the picture is composed of dots, or some kind of pattern. In print they're called dots on your monitor they're called pixels. Now paper is far more capable of carrying dots/pixels than your monitor is. Your monitor will do up to about 200 dots per square inch. This is why a lot of things look a little distorted or blurry on your computer display vs. paper.
Now a basic rule of thumb for image resolution on your monitor to print is that the image should look about 3-6 times as big on your monitor veiwing it at 100% or 1:1, as it will when you print it. There are big differences between two types of files, Raster files and Vector files. Vectors are just what they say based on direction. So you can take a Vector and make it as big or small as you want.
Vectors are used in stuff like fonts, and line art which you'd find in a comic. Rasters are images you'd take from your digital camera. Because there are so many features which change at resolution in a raster image you can only scale the picture down in size without loss in percieved quality. If you try to size the image up you're going to reduce the percieved quality of the image.
Let me show you an example of a print sized picture. This is how big you'd need the image to be, in order to be of sufficient
