Befuddled by Servo Choices
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Befuddled by Servo Choices
Page: [1]
Login
Befuddled by Servo Choices - 2/19/2007 2:21:26 PM
ClarkFlyer
Status: offline
I've only been involved with .40 size planes and I've always used std Futaba servos, 3004s, with no problem. Now I'm putting together a Twist .60, using an OS .91 two stroke and I understand I need beefier servos. I'm looking at all the choices and the wide variety of prices. I want to balance performance and cost and am not sure how to go. The Tower servos are a lot less in money but how are they in quality and life span? Who makes them? Also, I understand that metal gears are stronger but do not last as long. With my Twist, are they a good thing? Will the nylon gears work just as well? I've been told that a digital servo with torque in the 70-80 inch pound range will be ideal. Are there general rules in picking servo power? I'll appreciate any comments.
       Post #: 1
RE: Befuddled by Servo Choices - 2/19/2007 5:28:34 PM
sslayman
Status: offline
Good luck finding 70 to 80 inch pound servos . I think you meant 70 to 80 oz. inch servos. You might want to look at some 3152's (digital) or maybe even the HS-645MG's (analog). If money is no object then the Futaba 9252's would be a great servo. There are plenty of servo choices out there for what you want to do with them. Just do a search here on RCU for what's available and find something that you're comfortable spending the money on.
Later...
Scott!
_____________________________
Later...
(in reply to ClarkFlyer)
       Post #: 2
RE: Befuddled by Servo Choices - 2/20/2007 1:52:19 AM
P-40 DRIVER
Status: offline
The standard upgrade these day's would be to a Hitec 645 or digital 5645. Best price I have seen would be through Troy Built Models. Check the sight out, It has alot good info. These are very solid metal gear servo's that have plenty of torque but are still reasonably priced.
RC budget, $10 per week, time spent building and flying, priceless.
(in reply to sslayman)
       Post #: 3
RE: Befuddled by Servo Choices - 2/20/2007 6:02:04 AM
alan0899
Status: offline
G'day Mate,
Unless you are going to fly 3D, those standard servos will be fine, it's only a 90FS, I use 4.8 Kilo servos on my 160 size planes, except for the rudder, & have no problems.
Good Flyin Mate. Keep Thyne Airspeed up, lest the ground arise & smite thee, Allan.
       Post #: 4
RE: Befuddled by Servo Choices - 2/20/2007 6:03:05 PM
carrellh
Status: offline
quote:
ORIGINAL: ClarkFlyer
The "recommended" servos (page 3 of the manual) are JR537 or equivalent. These are standard ball bearing servos with a 40 ounce inch rating.
Regards,
Carrell
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
4.906RCU1
