hitec programmer problems
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Hitec/MultiPlex Radios- Ask Hitec Customer Service >> hitec programmer problems
Page: [1]
Login
hitec programmer problems - 2/20/2007 2:14:35 AM
Hyprmtr
Status: offline
I just purchased a brand new programmer(tester) from chiefaircraft. I Have 8 brand new 5645 hitec servos that I need to program for alierons. I attempted to program the first servo and it would give me different outcomes. First I would not beable to access the certian change on the programmer. Example: If I wanted to change the direction(reverse) somtimes it would say fail and other times it would let me program what I wanted. This also happens with the reset to factory specs mode. I would beable to reset the servo and other times it would say fail. I attempted this several times with different servos and it would always be the same outcome.
Is there anything I'm doing wrong or do I have a bad programmer?
Once agian the programmer and the servos are brand new.
Thank you,
Ken
       Post #: 1
RE: hitec programmer problems - 2/22/2007 6:22:16 AM
mglavin
Status: offline
We have had several reports of late of similar problems with specific servos or so it seems. I’ve made some inquiries with Hitec Service to determine if there is a pattern. But it seems the HFP-10 Programmer is suspect as other have solved their problems with through Hitec Service. I’d suggest contacting Service directly for information on returning the Programmer for a warranty service.
See the post at the top if this forum regarding Service and how to contact Hitec USA.
_____________________________
Michael Glavin
RCU Community Moderator
Hitec * Multiplex Field Representative
(in reply to Hyprmtr)
       Post #: 2
RE: hitec programmer problems - 8/13/2007 1:33:09 AM
markalign
Status: offline
Hi, would you be kind enough to give me the contact info. for hitec service in the USA as i also have a defective programmer.
(in reply to mglavin)
       Post #: 3
RE: hitec programmer problems - 8/13/2007 1:57:49 AM
A.T.
Status: offline
quote:
ORIGINAL: markalign Hi, would you be kind enough to give me the contact info. for hitec service in the USA as i also have a defective programmer.
Hitec Support details
You can always contact Hitec RCD USA service department @ service@hitecrcd.com in case a quick fix is available or call (858) 748-8440 to find out just how long the current turnaround time is.
Hitec Repair Request PDF
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
(in reply to markalign)
       Post #: 4
RE: hitec programmer problems - 8/13/2007 2:37:28 AM
markalign
Status: offline
Many thanks, i will try that.
(in reply to A.T.)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.422RCU1
