RE: Extreme Flight 88" Yak - Build and Fly    Gallery
Logged in as Guest
    Search This Thread
Printable Version
S&W 2-6S LCD Battery Capacity & Checker ***FREE SHIPPING US ONLY*****
Seller:  swgiantscalemodels
Details:   $19.89   |  4/2/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> RE: Extreme Flight 88" Yak - Build and Fly
Page: <<   < prev  9 10 [11] 12 13 14 15 16 17 18   next >   >>
Login
RE: Extreme Flight 88" Yak - Build and Fly - 2/24/2007 7:55 PM
Yak Man
Score: 100
Last Login: 9/3/2010
Status: offline
Headed to the LHS to p/up a steering arm and a few extras, looks like a short piece of nyrod and operate the choke from the front of the cowl. Similar to the original 87" KISS choke. Any idea about the nipples on Scotts' muffler and the plugged one in the back of the crankcase? Smoke?
< Message edited by Yak Man -- 2/24/2007 8:01 PM >
_____________________________
"I started with Nothing and I have most of it left."
Doug - "Prop-Wash makes Me HOWL!"
Hide Signatures
(in reply to Josey Wales)
       Post #: 251
RE: Extreme Flight 88" Yak - Build and Fly - 2/24/2007 7:58 PM
Josey Wales
Score: 100
Last Login: 5/16/2012
Status: offline
The plugged one on the backplate is if you want to run smoke..the one on the diaphragm cover plate is if you want to run a static line into the fuse..
Welcome to NJ...Where fun comes to die.
Joe
Hide Signatures
(in reply to Yak Man)
       Post #: 252
RE: Extreme Flight 88" Yak - Build and Fly - 2/24/2007 8:03 PM
jrjohn
Score: 100
Last Login: 1/21/2012
Status: offline
Just finished 1/2 my hinges, used pacer hinge glue. Water cleanup, no mixing, no oozing, no babysitting. Never had one fail yet. Super easy and clean.
Dave, looking at your pictures, I wonder if longer standoffs would be in order.
just say NO to monkey glue
John
< Message edited by jrjohn -- 2/24/2007 8:12 PM >
If we all think the same, only one of us is necessary
Hide Signatures
       Post #: 253
RE: Extreme Flight 88" Yak - Build and Fly - 2/24/2007 8:13 PM
Maudib
Score: 114
Last Login: 7/29/2011
Status: offline
JR John... you probably are wondering based on prop efficiency?
I certainly don't think more would hurt if someone wanted to go out another 1/2 or so...
On the 87" I went out further to make sure balance would not be an issue... but Chris says balance is not an issue here...
I did think that if someone wanted to do tail mounted servo... that the extra bit of the engine out would help offset that tail weight.
But I'm going to fly it as it is.
On the Brillelli 60... the plug cap is JUST touching the cowl... will epoxy a 1/8" pad of neoprene under it to prevent rattle and not have to make a little hole in the cowl there.
I can always add 1/2" blocks below the standoffs should I want to try it... but at this point I'm not going to second guess Chris on it...
But once any of us pay for the plane it's ours.. and we should feel free to do whatever we want to...
< Message edited by Maudib -- 2/24/2007 8:15 PM >
Hide Signatures
(in reply to jrjohn)
       Post #: 254
RE: Extreme Flight 88" Yak - Build and Fly - 2/24/2007 8:18 PM
jrjohn
Score: 100
Status: offline
Dave, your right, it's eficency that I'm thinking about. I wonder if the DA 50 sticks any further out? If Da makes 2 3/4 standoffs, I'd probably start with them. Or even 3''
John
< Message edited by jrjohn -- 2/24/2007 9:58 PM >
Hide Signatures
(in reply to Maudib)
       Post #: 255
RE: Extreme Flight 88" Yak - Build and Fly - 2/24/2007 8:25 PM
Yak Man
Score: 100
Status: offline
Manual arrived in the mail today, so plane should follow Monday.
Weighed stock Brillelli muffler 5.4 oz, definitely not the 3.1 oz lite vesion. Might go with the Stock DA muffler to save an oz and only have one exhaust hole thru cowl.
Hide Signatures
       Post #: 256
RE: Extreme Flight 88" Yak - Build and Fly - 2/24/2007 8:26 PM
krayzc-RCU
Score: 104
Last Login: 5/25/2013
Status: offline
so the finished product comes in around what weight?
smooth as silk!
Hide Signatures
       Post #: 257
RE: Extreme Flight 88" Yak - Build and Fly - 2/24/2007 8:36 PM
MustangAce
Score: 100
Last Login: 5/23/2013
Status: offline
What was the total weight Maudib??
Hide Signatures
(in reply to krayzc-RCU)
       Post #: 258
RE: Extreme Flight 88" Yak - Build and Fly - 2/24/2007 8:37 PM
thomasf
Score: 100
Last Login: 2/7/2009
Status: offline
Hey Maudib, Could one get away with running 1.25" servoarms on the elevator and ailerons? Thats what I have laying around, I also have a 2.75 staight arm for the rudder. Not enough HUH?
Trying to get everything needed for the plane so when it shows up (second shippment), I'll be ready.
Hide Signatures
       Post #: 259
RE: Extreme Flight 88" Yak - Build and Fly - 2/24/2007 9:08 PM
Maudib
Score: 114
Status: offline
I'm close but not quite ready to weigh.... later today for sure...
Thomas,
You COULD get by with 1.25 arms... just won't get all the throw... but quite a bit... in the long run you'd want to replace them out with th 1.5" though...
You pretty much HAVE to have the 4" offset arm to get proper gemotery and no slack in the cables... or fabricate one...
Hide Signatures
(in reply to thomasf)
       Post #: 260
RE: Extreme Flight 88" Yak - Build and Fly - 2/24/2007 9:44 PM
Maudib
Score: 114
Status: offline
Choke rod:
a segment of 2/56 all-thread
cut about 3/8" off the end of a 2/56 balllink
a segment of shrink tube
a plastic clevis
a grommet from Lowe's
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 261
RE: Extreme Flight 88" Yak - Build and Fly - 2/24/2007 9:52 PM
EAGLE PILOT
Score: 100
Last Login: 6/6/2012
Status: offline
As soon as I get some time tonite or tommorrow I'm going to mount this new 366GT that my favorite mail-lady just delivered! Man, this motor is a really nice piece of work! I appreciate when people like Scott and Chris take such pride in their work.
About a week ago I e-mailed Karl Mueller at Mueller Custom headers about him making an aluminum header for the 366GT. He has made one for the Brillelli 25cc but not the 60. His work can be viewed thru AeroBob's site. The price for Karl's header is $48.00 plus $8.00S&H. The aluminum header will be lighter than SS. I don't know how much. Karl can be contacted at kgamueller@rogers.com and all he needs are all pertinent dimensions: Exhaust flange, radius, drop and motor thrust angles and he can get started. If anyone is interested please PM me and "we" can take these measurements and agree that they are correct before sending them to Karl. Thanks, Nico
Hide Signatures
(in reply to Bosshossv8)
       Post #: 262
RE: Extreme Flight 88" Yak - Build and Fly - 2/24/2007 9:56 PM
juanvaldes_04
Score: 100
Last Login: 4/21/2008
Status: offline
Maudib, first of all THANKS for this GREAT build thread !!!!
Was wondering if your Ignition battery is a 4 cell AA pack..
Hide Signatures
       Post #: 263
RE: Extreme Flight 88" Yak - Build and Fly - 2/24/2007 10:05 PM
Maudib
Score: 114
Status: offline
Thank... and you are welcome...
It's a 4 cell AAA 730 nimh... 1.9 oz
Made from Sanyo 4H-730AAA cells... Maxx Products has them (out of stock right now)
When the next gen Roy Sholl's come out they will accept a 2 cell lipo/lion... and I may switch to a 2 cell lion/lipo
Hide Signatures
(in reply to juanvaldes_04)
       Post #: 264
RE: Extreme Flight 88" Yak - Build and Fly - 2/24/2007 10:21 PM
thomasf
Score: 100
Status: offline
Thanks Maudib, Making my list for Troy Built. I to would like to get the motor out farther then what you have pictured. I'm going to use a DA 50. I wonder what the gap is like with the 2.5 standoffs?
Hide Signatures
       Post #: 265
RE: Extreme Flight 88" Yak - Build and Fly - 2/24/2007 10:31 PM
Maudib
Score: 114
Status: offline
Yehaw!!!!!! Wahoooooooo! OH YEAH BABY!!!!!!!!!
I just put it all together, dropped a 4800 lion pack in there, the spinner cone (CF) and the throttle servo... BUT forgot the 4.1 oz DA stock muffler and the SmartFLy Reg with failsafe switch...
16.5 lbs!
Add the 4.1 oz for muffler, 1 oz for the reg and switch and 1 oz for velcro mounting the battery and throttle linkage and I got myself a 16.9 lb bird!!!!!!
Just about what I was expecting with 10.38 out of box.
I can't TELL you how excited I am with that weight... a DA50 and stock muffler will end up a tad over 16.5 lbs!
Both of which are gonna be AWESOME power to weight....
Again, I build light, and am choosey with what I put in... But I shared ALL my build... techniques and items selected... nothing anal here.
So Chris' 18.5 lbs is well... let's just say on the TOP end...
Remember mine does NOT have the spats, gear fairings or faux louvers... and I used 3.5" foam wheels (1.9 oz I think it was)...
I am SOOOOO pumped.
If you were to use that 6.5 oz gear JR John has brought to our attention, a 2 cell 2100 lipo on the receiver, DA50 with stock muffler and maybe went with the titanium axles... you'd be at 15.75 lbs DRY....
ANd olny a hair over 16 lbs witht he Brillelli 60.......
WoooooooooHoooooooo!!!!!
Hide Signatures
       Post #: 266
RE: Extreme Flight 88" Yak - Build and Fly - 2/24/2007 10:32 PM
jrjohn
Score: 100
Status: offline
quote:
ORIGINAL: thomasf
I'm with you on that one.
john
Hide Signatures
       Post #: 267
RE: Extreme Flight 88" Yak - Build and Fly - 2/24/2007 10:36 PM
Maudib
Score: 114
Status: offline
Same distance... the 60 and 50 are the same distance with stock standoffs...
I'd go ahead and get the 3" standoffs... it won't hurt a thing.
Hide Signatures
       Post #: 268
RE: Extreme Flight 88" Yak - Build and Fly - 2/24/2007 10:41 PM
diamondave
Score: 107
Last Login: 7/4/2012
Status: offline
excellent wieght!!!!!!!!
Hide Signatures
       Post #: 269
RE: Extreme Flight 88" Yak - Build and Fly - 2/24/2007 10:50 PM
dbrford
Score: 100
Last Login: 11/5/2010
Status: offline
Amazing weight for this size airplane. Looking at pics the fuse looks almost as long as my qq102. Looks like the items you left off are around 5oz or so, does that sound right? Getting real excited to put this one together.
"The sky is not the limit, the ground is."
Hide Signatures
(in reply to diamondave)
       Post #: 270
RE: Extreme Flight 88" Yak - Build and Fly - 2/24/2007 11:05 PM
Absolut Yak
Score: 100
Last Login: 8/1/2011
Status: offline
I'm going to hijack the thread for a moment, but you guys have more info than anyone I can think of. I did post on the gas engine forum. How many turns do I need on my high and low speed needles on my DA 50? I'm really having problems starting mine. I was going to do a thrust measurement today at the field so I could decide to use the DA 50 with Vess 23A on the new Yak or go with the Brillelli.
Doug
N67TP
Hide Signatures
(in reply to dbrford)
       Post #: 271
RE: Extreme Flight 88" Yak - Build and Fly - 2/24/2007 11:09 PM
Maudib
Score: 114
Status: offline
STart at 1.5 turns out on BOTH... that should get you started...
Is the engine in a plane? Newly plumbed? Sometimes it can be a bear to initally get fuel to the carb... especially if the run is long...
< Message edited by Maudib -- 2/24/2007 11:10 PM >
Hide Signatures
(in reply to Absolut Yak)
       Post #: 272
RE: Extreme Flight 88" Yak - Build and Fly - 2/24/2007 11:31 PM
EAGLE PILOT
Score: 100
Status: offline
Congrads Maudib! And thanks for all the tips and ideas. I don't get to build many airplanes so I am going to take my time and really enjoy building this one!
Hide Signatures
       Post #: 273
RE: Extreme Flight 88" Yak - Build and Fly - 2/24/2007 11:46 PM
TailTouch
Score: 100
Last Login: 2/20/2011
Status: offline
16.9 lbs !!!
Man that is heavy...very heavy for bird that almost presents like a 33% bird.
Will this have enough vertical ?
I can already see the plane losing speed in a vertical pullout because of the drag...
I don't know what's wrong with you EF fan club...
Yak Hole
Hide Signatures
(in reply to EAGLE PILOT)
       Post #: 274
RE: Extreme Flight 88" Yak - Build and Fly - 2/24/2007 11:55 PM
cadconversions
Score: 105
Last Login: 3/20/2013
Status: offline
quote:
ORIGINAL: TailTouch
16.9 lbs !!!
I'm glad you put all of the smiley's on there or someone would have about killed ya over tha comment...
Kevin
Hide Signatures
(in reply to TailTouch)
       Post #: 275
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.625RCU1
