RE: Extreme Flight 88" Yak - Build and Fly
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> RE: Extreme Flight 88" Yak - Build and Fly
Page: <<   < prev  244 245 246 247 [248] 249 250 251 252 253   next >   >>
Login
RE: ... - 7/13/2008 2:48:31 AM
diamondave
Status: offline
didnt have a chance to mess with my servo yet, was at the field with another plane i just got done, but i have a question for any of you formula junkies, dealing with a prop, ever heard of this?
DxDxDxP=?
a guy was doing that saying you can compare the load 2 different props will put on a motor, for example;
22x22x22x10=106480
23x23x23x8=97336
so according to him, the 23-8 will put less load then the 22-10, the bigger final number is more load, any body ever hear of that? do the numbers maean anything? he didnt really explain much about it just said its a rough way to calculate the load like that, just curious
(in reply to exakta777)
       Post #: 6176
RE: ... - 7/13/2008 3:05:52 AM
JoeAirPort
Status: offline
22x10=220
23x8=184
The math is way easier.
The two numbers do effect engine load but not sure if the relationship is as we have in our math. Any prop PHD's out there?
_____________________________
Joe AP
(in reply to diamondave)
       Post #: 6177
RE: ... - 7/13/2008 3:07:22 AM
rcbill
Status: offline
Dave,
I'm no expert, but it sounds complicated to me. I used something similar but it was like 22x10=220 and 23x8=184 for prop load comparisons. Not an exact science but just to give you an idea if you are in the same ball park.... Bill
       Post #: 6178
RE: ... - 7/13/2008 3:09:57 AM
rcbill
Status: offline
How about that??? Almost sounds like a double post..... Bill
(in reply to JoeAirPort)
       Post #: 6179
RE: ... - 7/13/2008 1:59:26 PM
diamondave
Status: offline
i thought it was alot of math to do, when he explained it to me, i used my calculator on my phone and just went 22x3, then x10, he said you cant do it that way it had to be 22x22x22x10, so i dont know, thats why i was asking more about it with all you smart fellows , plus i was a little suprised that the 23-8 was less load then a 22-10, i know the pitch is higher but i thought the more mass of the 23 would equal to more load but i guess not, you easier way says the same thing too
(in reply to rcbill)
       Post #: 6180
RE: ... - 7/13/2008 3:06:41 PM
xtraflyr
Status: offline
We need Mr. Vess to answer this!! He is after all a Propologist
Cya,
Frank
www.njjf.org
www.njjf.freeforums.org
       Post #: 6181
RE: ... - 7/13/2008 3:16:23 PM
rcbill
Status: offline
Dave,
I have a tendancy to think that the 23x8 would put a bigger load than the 22x10. The extra diameter plus the extra weight of the prop and drag etc makes me think that way. Like I had mentioned perhaps it's just to see if you are in the ball park on load when changing from something like a 21x12 to a 23x6....???? I duno.... Anyone else with the proper math is welcome to join in.... I'm sure Dick Hanson or Pat Roy or TKG would have a more appropriate explaination.... Bill
       Post #: 6182
RE: ... - 7/13/2008 3:44:33 PM
JoeAirPort
Status: offline
You prolly get more (static) thrust out of the 23x8 but more (dynamic) air speed out of the 22x10. I wonder if one loads the engine more at both static and dynamic conditions.
Joe AP
       Post #: 6183
RE: ... - 7/13/2008 4:19:38 PM
rcbill
Status: offline
Joe,
I'm gonna stick with "I dunno"..... Bill
       Post #: 6184
RE: ... - 7/13/2008 6:55:40 PM
JoeAirPort
Status: offline
quote:
ORIGINAL: rcbill
Joe,
Well at least you're smart enough to stick with that....I think I'll follow suit.
Joe AP
       Post #: 6185
RE: ... - 7/13/2008 10:31:52 PM
Richard D Bahmann aka/Wrongway
Status: offline
How about the one that loads the engine the most is the one with the lesser RPM?
Check out the prop calculator of Pei Reivers at www.mvvs.nl or ask him in my opinion, a real expert.
Gonna kick the tire and light up my
Torch...Gone Flying...WrongWay
       Post #: 6186
RE: ... - 7/14/2008 1:25:24 PM
Flyin Hawaiian
Status: offline
I know that this Engine / Prop Load Calculation makes for great discussion, but totally unecessary. Most of us already know that works for most 50cc applications, the 22-8 to 22-10 and 23-8 props will work. But if you do not factor in the atmospheric conditions (altitude) it really is a moot point. What it really boils down to is performance you can feel through your thumbs: Engine RPM's, Engine Temperatures, aircraft selection, and aircraft weight, still needs to be factored in. No I am not a formula junkie, (even though I deal with formulas with my Job every day) but I know what works and what does not work. Formulas are a good way to find a good starting point, but real world results that is shared here amoungst ourselves, is what matters!
Rennie "Fly Low & Slow & In Control!"
Team Extreme of extremeflightrc.com / B & E Graphix
