TrikeFlyer
Joined: 2/14/2007 From: Rowlett, TX, USA Status: offline
Hey Hardtop roger that spark!! My GH26I now has over 2 hours on it with a Hawk 16X8. Choke venturi with thumb (EI off) flip 10 times to prime, turn EI on it starts on 2nd or 3rd flip if cold and first run of day. If it is a rerun, I coke it, flip 3 or 4 flips then turn on EI and it almost always starts on the FIRST flip!! This engine now runs like a swiss watch. All time is on my test bench with 10 min run, 10 min cool off, 15 min run, 15 min cool off, etc.. This engine did initially exhibit the "tightness" when I over primed it, but after one or 2 "runs" this went away. The compression is getting better and better after each run and cool down cycle. Also, at first I did not have the idle screw open enough to overcome the intitial friction of the new engine and I had trouble getting it to run . After a few runs I have have now turned the idle way down from where I first started. It will go into my Laser 200 this next week for maiden flight probably next Saturday. As soon as I get a nice selection of props I will do some RPM tests and post the results early next week. Regards - Trike
