Ratchet
Joined: 10/29/2002 From: Ottawa, ON, CANADA Status: offline
Hey Guys, I've been following this thread for awhile as I have a GF26-ISP engine that I'm currently installing into my Lanier Laser. Trikeflyer - I'm assuming your Seagull Laser is roughly the same size as mine. My concern is spacing between the receiver and the ignition module. I've always been told/read to keep them at least 12" apart in a gas plane. The problem here is that this is very hard to do in this airplane. I managed to separate the components only about 9". How far apart are your components? So basically, is anyone having any ignition related glitching that would be a concern? Second question - has anyone been able to install a spinner? I can't find any adapters that will work for this engine. Other then using a Du-bro nylon spinner, which I don't want to do in a gas plane, what are others doing? Thanks ... =R
