2robinhood
NJ, USA Status: offline
OK, I just did the swap on my Seagull Laser 200. I weighted everything to do the swap and here is what the verdict is: Taking out. OS Max 1.60FX ( 2 stroke ) with Bisson pitts muffler, Seagull stock aluminum motor mount, engine to mount bolts, mount to firewall bolts, prop and spinner. Total is 3lb. 3.2 oz. Puting in. CRRC Pro GF26I with CRRC pro pitts muffler, custom made 2 3/4" stand offs, stand off mounting bolts, ignition, ignition battery and switch, prop and spinner. Total is 3 lb. 4.9 oz. I am going to use the same tank, so no differance there. So, an all out even exchange of motors ready to fly gained me 1.7 oz. and about 550 - 600 more rpm with a much better prop. OS with a 18 X 6 Master airscrew wood 7250 rpm. CRRC with a Xoar 18 X 6 wood 7800 rpm. When I get it up in the air, I'll let you guys know.
