RE: CRRC PRO GF26I
Tower Hobbies
Logged in as Guest
  Printable Version
MT FLEX HEADER & CANSTER For MT50,57, 62, Brillelli GT 366, DL50,DA50,G62 ENGINES
Seller:  mistydee0
Details:   $149.00   |  7/17/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: CRRC PRO GF26I
Page: <<   < prev  5 6 [7] 8 9 10 11 12 13 14   next >   >>
Login
RE: CRRC PRO GF26I - 1/1/2008 2:43:43 AM
denney47
Status: offline
The spark plug that comes with the CRRC Pro 26cc is a Torch CMR7H.
Tom
Valley View RC
(in reply to 2robinhood)
       Post #: 151
RE: CRRC PRO GF26I - 1/1/2008 5:14:57 AM
brockettman
Status: offline
Tom,
Here's another question for you...
What are the thread sizes on the outer prop shaft for the prop nut, and the smaller inner threads for the spinner screw?
Thanks, and Happy New Year!
Ben
Fly low, fly fast....
_____________________________
Club SAITO Member #565
(in reply to denney47)
       Post #: 152
RE: CRRC PRO GF26I - 1/1/2008 5:20:17 AM
brockettman
Status: offline
2robinhood,
It's been a couple of months since I ran my engine, but I seem to remember getting a good 40-45 minutes of run time with a fresh charged Futaba 4.8 600mAh pack. Just one of the square reciever packs.
Good luck....
Ben
       Post #: 153
RE: CRRC PRO GF26I - 1/1/2008 4:16:32 PM
Ratchet
Status: offline
Hi Ben - the "inner" thread on the engine is 4mm. I'm not 100% sure, but I think the outer is an 11mm.
=R
(in reply to brockettman)
       Post #: 154
RE: CRRC PRO GF26I - 1/1/2008 7:12:51 PM
denney47
Status: offline
quote:
ORIGINAL: brockettman
Tom,
Ben
Hello Ben,
Please contact our enging tech. Jody at: jody.valleyviewrc@comcast.net he knows all of the technical info, I am in sales and would only be making a guess.
You will like this engine.
Tom
Valley View RC
       Post #: 155
RE: CRRC PRO GF26I - 1/9/2008 3:17:54 AM
2robinhood
Status: offline
OK, I just did the swap on my Seagull Laser 200.
I weighted everything to do the swap and here is what the verdict is:
Taking out.
OS Max 1.60FX ( 2 stroke ) with Bisson pitts muffler, Seagull stock aluminum motor mount, engine to mount bolts, mount to firewall bolts, prop and spinner.
Total is 3lb. 3.2 oz.
Puting in.
CRRC Pro GF26I with CRRC pro pitts muffler, custom made 2 3/4" stand offs, stand off mounting bolts, ignition, ignition battery and switch, prop and spinner.
Total is 3 lb. 4.9 oz.
I am going to use the same tank, so no differance there.
So, an all out even exchange of motors ready to fly gained me 1.7 oz. and about 550 - 600 more rpm with a much better prop.
OS with a 18 X 6 Master airscrew wood 7250 rpm.
CRRC with a Xoar 18 X 6 wood 7800 rpm.
When I get it up in the air, I'll let you guys know.
       Post #: 156
RE: CRRC PRO GF26I - 1/9/2008 4:30:16 AM
denney47
Status: offline
Make sure you change your tank over to gas, you will need a new gas stopper and Tygon gas lines.
Tom
Valley View RC
       Post #: 157
RE: CRRC PRO GF26I - 1/10/2008 7:12:03 PM
ramduster
Status: offline
My son is thinking about getting this engine for his ultra stick lite 120. He was going to get a g26ei but this engine being 100.00$ less in price it is hard to pass up. So what I would like to know is are you guys more or less happy with the CRRC PRO GF26I.
       Post #: 158
RE: CRRC PRO GF26I - 1/11/2008 5:04:16 AM
denney47
Status: offline
We have sold a lot of these engines and customers really like them. We have had a couple of minor repairs but nothing major, seems like a real good engine.
Tom
Valley View RC
(in reply to ramduster)
       Post #: 159
RE: CRRC PRO GF26I - 1/12/2008 2:20:32 AM
brockettman
Status: offline
ramduster,
It's a little soon to tell without having a good season of flying with this engine. I've run my GF26i on a test stand for a bit less than two hours. So far so good, starts fine and runs smooth... I did get it mounted to the firewall in my Mustang last week...
Ben
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 160
RE: CRRC PRO GF26I - 1/12/2008 2:30:23 AM
denney47
Status: offline
There is Pitts style mufflers available for these engines at www.valleyviewrc.com
Tom
       Post #: 161
RE: CRRC PRO GF26I - 1/12/2008 5:42:49 PM
brockettman
Status: offline
Thanks Tom,
I do have the Pitts muffler and was intending on using it on this plane. I still might, but the way this crazy Asian ARF is set up for engine mounting I 'll have to do some major re-design on the firewall area. If the standard muffler will fit inside of the cowling I may just go with it. It's gonna be close...
Ben
       Post #: 162
RE: CRRC PRO GF26I - 1/12/2008 8:16:05 PM
denney47
Status: offline
Should be a great airplane, send some pics when you get it finished.
Tom
Valley View RC
       Post #: 163
RE: CRRC PRO GF26I - 1/15/2008 12:44:40 PM
ramduster
Status: offline
Thanks guys for the info about the engine but a Friend found my son a g26 for 150.00$ bucks last Sunday and could not pass that up. But I may get one of the crrc gf26i for my self later this year for a cub that I plan on getting. Thanks for the help.
       Post #: 164
RE: CRRC PRO GF26I - 1/22/2008 4:40:44 AM
2robinhood
Status: offline
quote:
ORIGINAL: denney47
Valley View RC is the factory authorized service center for CRRC Pro. All new CRRC Pro 26cc engines are being shipped with a 4.8V sticker on the ignition and noted in the manual. For additional information contact www.valleyviewrc.com
Tom
Here was my problem ( post 145 )
Well I was using the 6V till I read this.
I started using a 4.8V. I have been bench running it, and when my 4.8V reaches 4.9V on a meter the engine quits.
I haven't been able to get good running time from a 4.8V 1000mah pack ( test pack ).
I contacted the guy I bought the motor off of ( http://www.prcmodel.com/index.php ) and he said that he hasn't heard anything from CRRC about a voltage change.
OK, I bought some two brand new 4.8V 1650mah NiMH pack Fully charged @ 5.53V ( no load ) 5.48V ( with load ).
Motor starts and runs, but idle is bad. Idles for a minute / minute and a half and shuts down. While it is idleing every so offen it will miss.
The only way to keep it running is to raise idle rpm's.
Best idle to stay running is 2050 rpm. I tried both 4.8V packs with the same result.
I put my 6V 1650mah NiMH pack back on.
Fully charged @ 6.72V ( no load ) 6.67V ( with load ) and the motor runs perfect. No miss, idles reliable down to 1825 rpm and will idle for 30 minutes perfectly.
I didn't take any wide open rpm numbers with each battery to know if there is a differance in top rpm.
But there is definately is on idle rpm's. It also starts much easier with the 6V pack.
Anyone with any ideas????
