2robinhood
NJ, USA Status: offline
quote:
ORIGINAL: jeffk464 I have a question for all of you CRRC 26 owners, are you all running metal gear servos and is it necessary. I have an 11lbs plane extra with a super tiger 2300, a ridiculously high torque metal gear on rudder, 2 Hitec 475HB on elevator, and 2 hitec 475HB on ailerons. This setup works fine with the st 2300, but will it also work fine with the crrc 26? Looking at the numbers they put out about the same power, but I hear gassers shake a whole lot more and might strip non metal servos. Always, always use metal gear servos on gasser. The frequency of the vibration of a gasoline engine is much different the glow engines. It is not the power of a gasoline engine that does it, you can use plastic gears in a 1.60FX glow without any issue. The 1.60FX is more powerful then any 26cc gas engine. It is the vibration of a gasser that kills plastic gear servos.
