js3
CO, USA Status: offline
quote:
ORIGINAL: DonStegall John, The ToughLon is not the best covering. But using ToughLon over ToughLon works much better than trying to put MonoKote or Ultracote on it. Because the shrinking temperature of ToughLon is only 250, you have to use a low temp covering for trim. EconoKote works fine, but color choices are limited. AirBorne Models stocks a large range of colors of ToughLon. Even more than are on their web site. The World Models catalog lists all of the available colors. I got the ARC done so that people don't have to strip the ToughLon off. ToughLon will sometimes leave the adhesive and color if it is stuck on real well. You have to use acetone to remove the residue. With the ARC, this is a non-issue of course. Your color scheme looks cool. You seem to like that Yellow Jacket theme. Thanks Don. What price are you selling the ARC Skyraider for? Yeah, I found that the heat I needed for the monokote really played havoc with the ToughLon. It looks pretty good from a distance but up close... well, I'm not very proud of this one. And now, it has an Arizona Iced Tea alum can wrapped around the LE of the right wing. I had to do a quick field repair after hitting and knocking down pylon 2 on Saturday. First time I've ever hit a pylon. Truth be told, I don't really care for the way this color scheme looks. But there are a couple of reasons I chose it. One, it's really easy for me to see. The yellow with a dark contrasting color is great for my eyes. I've had several planes using yellow and some other dark color. But what I really do like about it is that I've only seen one plane with this schemethe full sized Yellow Jacketnever any models. I really like to have things that are distinctive.
_____________________________
John I feel a lot more like I do now than I did earlier!
