Rube Goldberg
Joined: 6/5/2006 From: Whale Tail, RI, USA Status: offline
Fellow club member just finished a Pole Cat, and asked my thoughts on engine selection. IMO the most "bang for the buck" (since he is a turbine jet type flyer) in a 40 or so size engine hands down would be the SuperTigre G-45ABC. I've got one on my yellow Long-EZ, and it runs like a top. So the phone rings this afternoon. It's my buddy with the Pole Cat. Can't get this %$&@$& SuperTigre piece of %^%$&% to run worth a %Y%^!! He's pretty livid, and it's his first ST engine. "Guess you get what you ^#@^&^ pay for!" I tell him hang tight, I'll be outta this cow pasture where I'm surveying and be right over. Few hours later he is still working with it. He's got the correct APC 10X7 prop and I guess he's got good fuel. Symptoms are it can be choked at the carb and then with the throttle a few clicks above low throttle position it will run for only a few seconds then quit. Won't re-start until it is choked again. He's already checked the plumbing of the tank. It is ok. Blow through the vent and it flows through the clunk line. Tried getting it running a couple more times and same thing. Decided to use my fuel, and when I pull off the vent line at the muffler....... "PHOOOOOOOOPPPPPP"! Hmmmmm, me thinks. That can't be right. Fill it up with my fuel, leave the vent line off the muffler and it fires right up on the first hand flip. Runs like a scalded dog. Problem nearly resolved, but what is going on with this vent line/muffler connection?? Take a very small allen wrench and insert it into the pressure nipple on the muffler. Hmmm, it stops. Remove nipple and take a look.......it's got a piece of plastic in it! Kind of a blue and white rubbery plastic, almost like the factory worker dipped the nipple in thread lock and then installed it into the muffler! Well that makes sense.....the whole time with the vent line installed to the muffler, the tank was drawing a vaccuum. Choking the engine would pull the fuel up, but that's it. The fuel was being sucked back to the tank! Unclog nipple, refit vent line to the muffler and we're good to go. When I left him the engine was running at a high idle for the past 10 minutes and didn't miss a beat, and he was grinning ear to ear especially after I told him to hang on to the plane while I went full throttle. That's gonna be one FAST airplane! Rube
