RE: Pole Cat 50 - 51" ARF
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> ARF or RTF >> NitroModels Support >> RE: Pole Cat 50 - 51" ARF
Page: <<   < prev  1 2 [3]
Login
RE: Pole Cat 50 - 51" ARF - 4/26/2008 8:46:41 PM
triboyeric
Status: offline
Anything in between the .32 and the .46 that would do well?
I just want a good sport plane. So a 13 x 6 for the best performance????
Eric
_____________________________
Keep your thumbs on the sticks!
(in reply to opjose)
       Post #: 51
RE: Pole Cat 50 - 51" ARF - 4/26/2008 10:06:47 PM
opjose
Status: offline
You could put in any good .40.
Avoid an .40LA though as it is less powerful than a standard .40.
Prop size is determined by what you are trying to achieve along with the engine size you used.
I flew the plane again today, this time with a MA 11x7.
I liked the speed and performance.
I may try a 10x8 to see if I can get more high end RPM's out of the plane tradiing off it's existing ( almost unlimited ) climb rate.
I've had no problems with the new stock elevator even during hard snaps.
< Message edited by opjose -- 4/26/2008 10:09:39 PM >
Build em'', fly em'', crash em'' and build more.
(in reply to triboyeric)
       Post #: 52
RE: Pole Cat 50 - 51" ARF - 4/27/2008 12:09:20 AM
triboyeric
Status: offline
With the OS .32, ill try a 10 x 6 apc. Should be good for aerobatics/sport flying.
Eric
       Post #: 53
RE: Pole Cat 50 - 51" ARF - 4/27/2008 9:58:05 PM
opjose
Status: offline
Polecat .50 with O.S. AX .46 engine, dubro muffler extension, Mac muffler pipe, MA 11x8 prop.
Minimal cowl cutting needed, and the engine is almost completely hidden.
Note fuel dot at tip of chin faux oil cooler intake.
The right cheek hole is for the ignitor.
< Message edited by opjose -- 4/28/2008 4:38:53 PM >
       Post #: 54
RE: Pole Cat 50 - 51" ARF - 4/29/2008 1:12:56 AM
triboyeric
Status: offline
NICE!!! Anybody have a video of the pole cat flying?? I already saw the ones on the internet and you cant really see the plane.
Eric
       Post #: 55
RE: Pole Cat 50 - 51" ARF - 4/29/2008 4:48:24 PM
opjose
Status: offline
Have you seen this one?
Click me!
BTW: Mine seems considerably faster than the one in the video.
My level, full throttle flying speed appears to be about the same as what the pilot achieves in the video with a full throttle dive, as the plane passes by.
I also get MUCH quicker rolls.
       Post #: 56
RE: Pole Cat 50 - 51" ARF - 4/30/2008 10:39:22 PM
triboyeric
Status: offline
Yep seen that one. Probably becuse that plane is electric and the one you have uses a .46 when the recommended power is up to a .46
Eric
       Post #: 57
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.360RCU1
