Fuel for a O.S. Max .25FX
Tower Hobbies
Logged in as Guest
  Printable Version
Area 51cc Gas Engine - RTF
Seller:  Milton
Details:   $399.95   |  6/30/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> Fuel for a O.S. Max .25FX
Page: [1]
Login
Fuel for a O.S. Max .25FX - 2/26/2007 6:06:29 PM
alexdeliu
Status: offline
Recently I bought a new os max 25 fx series for my LuckyStar trainer. What fuel is the best for this engine ? I want to use a fuel with 5% or max 10% nitro. What do you recomand ?
       Post #: 1
RE: Fuel for a O.S. Max .25FX - 2/27/2007 1:29:56 AM
downunder
Status: offline
It depends on what brands of fuels are available to you. Read the labels and check the contents and avoid anything that doesn't tell you exactly how much oil is in it. Personally I'd go for any fuel that has at least 20% oil and a high proportion of that being castor.
(in reply to alexdeliu)
       Post #: 2
RE: Fuel for a O.S. Max .25FX - 2/27/2007 8:48:09 AM
alexdeliu
Status: offline
From my country I can buy :
Magnum with 5% or 10% nitro
Tornado with 5% or 10% nitro
Graupner Titan with 5 % nitromethane content and 22% purified lubricant
Morgan Cool Power with 5%
What you recomand?
(in reply to downunder)
       Post #: 3
RE: Fuel for a O.S. Max .25FX - 2/27/2007 1:06:46 PM
downunder
Status: offline
Magnum...forget it because they won't list the ingredients.
Tornado...hard to say because all I could find was that they make fuels for cars so it's likely to have very low oil content and all they seem to advertise is nitro content.
Morgan Cruel Power...oops, Cool Power has low oil (17%) and all synthetic.
Morgan Omega also has only 17% but at least some of it is castor.
My pick would be the Graupner, they've got a good reputation and I believe the oil they use is Aerosynth or Aerosave which, although not castor, is supposed to be very good.
       Post #: 4
RE: Fuel for a O.S. Max .25FX - 2/27/2007 1:26:53 PM
alexdeliu
Status: offline
Thank you very much downunder, I will consider your advice.
Cheers,
Alex
       Post #: 5
RE: Fuel for a O.S. Max .25FX - 2/28/2007 12:01:47 PM
asmund
Status: offline
Those Graupner oils is very good and is about all that is used here in Norway. Aerosave, aerosynth, Aerosynth competition. They are all great. We actually mostly use 15% oil content too, no worn out engines around here for years and years of use
       Post #: 6
RE: Fuel for a O.S. Max .25FX - 2/28/2007 7:28:07 PM
alexdeliu
Status: offline
Anyone use Magnum 5%? It is the cheapest and I know that it is prepared with ricin oil.
(in reply to asmund)
       Post #: 7
RE: Fuel for a O.S. Max .25FX - 3/9/2007 5:50:17 PM
wcmorrison
Status: offline
quote:
ORIGINAL: alexdeliu
I would rather you not refer to Castor Oil as ricin oil. The skin of the Castor Bean is used to produce ricin, the innerds of the bean gets pressed and releases the oil. The oil does not have any ricin in it, in fact is not poisonous. Ricin is poisonous! It is one of the most deadly poisons around.
Castor Oil is also used in baking and for medicinal purposes, that which is used in medicine has been purified a bit more and thus is not as good for lubrication in methanol fueled engines.
So while both products are from the Castor Bean, one is poisonous and one is not.
The OS FX is low compression engine and requires some nitro in the fuel. It will run best on 15% nitro fuels and will run its worst on 0% nitro in the fuel (due to lower compression). You may remove the head and see it there is a space/shim used between the head and the crankcase. If so, remove the spacer and the compression will be raised a bit and make the engine a better performer with lower or zero nitro enhanced fuel.
Cheers,
Chip
       Post #: 8
RE: Fuel for a O.S. Max .25FX - 3/13/2007 4:10:19 AM
RaceCity
Status: offline
WCM...
Unfortunately, "Ricin Oil" is a literal translation from a number of foreign languages. ie: (Cesky) "Ricinus Oleje"
It's OK man!!! We can still call our beloved bean "castor", but in fact...much of the world calls it ricin oil.
Oh well.
_____________________________
AMA 63990
(in reply to wcmorrison)
       Post #: 9
RE: Fuel for a O.S. Max .25FX - 3/15/2007 11:02:28 AM
alexdeliu
Status: offline
In my country anyone calls it RICIN OIL. (ULEI DE RICIN translated in romanian). Nobody calls it Castor oil.
(in reply to RaceCity)
       Post #: 10
RE: Fuel for a O.S. Max .25FX - 3/15/2007 6:08:06 PM
carrellh
Status: offline
quote:
ORIGINAL: alexdeliu
Our club got together a 50 case buy from Magnum a couple of years ago. I bought 3 cases of their 10% sport fuel. Before we ordered, our club president talked to "Buzz" on the phone and expressed concern about the lack of info regarding oil. He was told they use 20% oil in the "sport fuel." We had people getting 0, 10, 15, and 30% nitro. The fuel runs great and I wouldn't hesitate to buy more of it.
Regards,
Carrell
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.781RCU1
