Harvard tip stall
Tower Hobbies
Logged in as Guest
  Printable Version
Airworld BAE Hawk - ARF
Seller:  rambat1
Details:   $16,000.00   |  12/27/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Aerodynamics >> Harvard tip stall
Page: [1]
Login
Harvard tip stall - 2/26/2007 6:46:52 PM
west6008
Status: offline
Just finished test glides on a .10 powered Harvard/AT-6
WHAT a nasty tip stall!
The CG is ok
Has washout in wingtips.
The stabilizer incidence is zero degrees
The wing is plus 2 degrees
No ailerons, rudder and elevator only
I've had a free flight Harvard that was quite tame.
Maybe I have the elevator set too touchy?
       Post #: 1
RE: Harvard tip stall - 2/26/2007 6:49:29 PM
Tall Paul
Status: offline
Yup. The elevator is too touchy!
The T-6 is a horrible airplane, no matter how you look at it!
The full-scale was bad, models are just as bad.
Move the c.g. forward a bit, and cut down the elevator travel.
_____________________________
Sparky Paul
http://www.angelfire.com/indie/aerostuff
(in reply to west6008)
       Post #: 2
RE: Harvard tip stall - 2/27/2007 3:23:25 PM
Balsa Shavings
Status: offline
There's an old saying about the T-6 Texan. It's not safely landed until it is tied down on the ramp. I have built a couple of T-6's, and all of them have went to the giant hanger in the sky. Tame down the elevator and use some expo on it, if you can.
Keep The Faith: Johnny
Oh, The Sweet Smell Of Nitro & Castor Oil !!!!!!!!
(in reply to Tall Paul)
       Post #: 3
RE: Harvard tip stall - 2/27/2007 5:41:00 PM
mesae
Status: offline
It made a good trainer though - it "encouraged" good flying habits in preparation for the real fighters.
"The purpose of time is to prevent everything from happening all at once."
(in reply to Balsa Shavings)
       Post #: 4
RE: Harvard tip stall - 2/27/2007 10:34:02 PM
west6008
Status: offline
Thanks everyone--I also cut down the weight by clawing a bunch of wood out of the airplane,
and removed the muffler from the OS .10
It should have a realistic cackle now!
Will post pictures in the 1/2 A Forum in a month or so
-that is, if it decides to fly!
(in reply to mesae)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.438RCU2
