voltage error
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> Common Sense RC Support >> voltage error
Page: [1]
Login
voltage error - 2/26/2007 7:00:28 PM
GATORl
Status: offline
hello.. i have a multiplex LN-5014charger and the battery im having problems with is
a thunderpower 2100mah 11.1v 15c cont/ 24c burst 31(31.5a/50a).
i set the charger to the same and after a minute or 2 it beeps and says input voltage error..it is powered by 2 12volt batteries
Any input is welcome..
< Message edited by GATORl -- 2/26/2007 7:15:30 PM >
       Post #: 1
RE: voltage error - 2/26/2007 9:04:34 PM
guver
Status: offline
It sounds like a connection/bad input battery. Can you view or test the input voltage when you push start?
If it gives error after 1-2 minutes then is an idication of low input voltage.
_____________________________
you hear that silence?
(in reply to GATORl)
       Post #: 2
RE: voltage error - 3/8/2007 1:33:21 AM
chilie
Status: offline
I have the same charger.
I just bought a 5 cell battery and after a minute or two, it starts beeping at me saying low voltage. I looked in the manual and it says that error will show if the voltage is above 15v. This is has to be a flaw in its design since a 5 cell is rated at 18.5 nominal.
I think there's just a bug with it. There must be a problem with the cell detection or voltage detection. I cant figure out which one it is.
(in reply to guver)
       Post #: 3
RE: voltage error - 3/8/2007 5:34:25 PM
guver
Status: offline
Are youi sure we aren't confusing input voltage (15 v) with low output voltage?
(in reply to chilie)
       Post #: 4
RE: voltage error - 3/8/2007 10:20:08 PM
chilie
Status: offline
ahh..yes I was.
Sorry for the confusion. I'd probably help if I didn't read so fast
Upon reading the original post more slowly and digesting what you are asking, the only thing I can think is that you have your two 12v batteries wired in series (making 24v) and not parallel. I run two 12v batteries for with the same charger.
Does your charger work if you only had one of the 12v batteries connected?
(in reply to guver)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.594RCU1
