Brass Tubing
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Questions and Answers >> Brass Tubing
Page: [1] 2   next >   >>
Login
Brass Tubing - 2/11/2003 4:34:32 AM
fly4food18
Status: offline
I am working on my fuel tank, and i am having trouble bending the brass tubes with out denting them. As i bend them they seem to form a dent away from where i am bending them. Is there a way to bend the tubing with out doing this. My Local hobby shop doesn't have the tool that dubro makes, I have asked them to order it for 3 weeks now and nothing.
Any advice will help me.
fly boy
       Post #: 1
Brass Tubing - 2/11/2003 5:10:09 AM
mscic-RCU
Status: offline
try bending it around a piece of pipe, like 1/2" or 3/4" pvc or copper. you can bend it by hand, but you must go slow and try not to make the radius of the curve to sharp.
(in reply to fly4food18)
       Post #: 2
Brass Tubing - 2/11/2003 5:13:36 AM
rcalfred
Status: offline
Sometimes the brass tubing we get is hard. One way to help with bending it is to anneal it. Heat it with a propane torch and it will soften it. Experiment a bit to get the right amount of heat--it will be surprisingly high! Regards.
_____________________________
Al Sortwell
AMA 15663
       Post #: 3
Brass Tubing - 2/11/2003 5:18:42 AM
Stick Jammer
Status: offline
Make a run to the hardware store and find the stiffest spring that has an inside diameter that just fits snugly over your tubing and is long enough to cover the intended bend. Put the spring over the section that you want to bend and go to it. The spring will keep the tubing nice and round, then just remove the spring by twisting and pulling.
       Post #: 4
Brass Tubing - 2/11/2003 5:25:20 AM
Geistware
Status: offline
Put a piece of wire inside the brass tube then bend it.
Once bent, remove the wire.
Aircraft Proving Grounds
http://www.rcaircraft.net/
Information on the building and flying of Radio Control Aircraft.
Site for hobbyist in the R.C. Aircraft modeling world.
       Post #: 5
Brass Tubing - 2/11/2003 5:44:11 AM
tpstorey
Status: offline
I use a piece of .08" weed whacker nylon line inside the tubing. This seems to be the perfect size for bending the tubing that comes with fuel tanks, copper or aluminum. You can get very tight bends without kinking and the line is slick enough that it pulls out easily when finished.
       Post #: 6
Brass Tubing - 2/11/2003 6:37:52 AM
Ernie Misner
Status: offline
Now for the micky mouse way.... but it works if you don't have any tubing bender tools at your disposal. Take a pair of needle nosed pliers and start making your bend. It will put little kinks in the tubing. Now take a regular pair of pliers and squeeze the tubing from the sides and it will flatten out the kinks. Repeat... and go slowly.
Ernie
       Post #: 7
Brass Tubing - 2/11/2003 7:12:13 AM
big max 1935
Status: offline
Bought 1/8" copper tube from auto parts house. Some sell by ft. Bends easy. >>>>>>>>big max 1935
       Post #: 8
Brass Tubing - 2/11/2003 11:39:50 AM
Hircflyer
Status: offline
Fill it full of sand... tape the ends ...then bend.....works well.
Finally! Everyday is a weekend
       Post #: 9
Brass Tubing - 2/11/2003 12:28:23 PM
Ernie Misner
Status: offline
Hi Big Max - copper or brass? Doesn't copper corrode with glow fuel?
Ernie
       Post #: 10
Brass Tubing - 2/11/2003 8:28:04 PM
big max 1935
Status: offline
Ernie :Can`t say that I have by using copper had any trouble with corrosion, but I always have made sure tanks were empty after flying. Then again it could be that my planes don`t last long enough for corrosion to set in!! Bought a 25ft roll of it years back & am still nibbling at it, bought from NAPA >>>>>>>>>> big max 1935
       Post #: 11
Brass Tubing - 2/11/2003 8:31:51 PM
Tippie
Status: offline
Wire, weed wacker line, sand (works good for large tubing) inside the tube and bending the tube inside a tight spring are all good ideas that work. Sorry Ernie, pliers don't sound 'neat' to me. Pay attention to 'big max 1935', he as nearly 100 years of experience, or is it 90, no 85, could be 67. HA
       Post #: 12
Brass Tubing - 2/11/2003 10:35:59 PM
MinnFlyer
Status: online
I often do the copper tubing thing too. It only costs 50 cents a foot at the Auto Parts store, and I usually run it from the tank right through the firewall. That way, there's no fuel line that can break, leak, slip off, etc. somewhere that's not easily accessable. (and it bends like a dream compared to brass)
Mike B.
AMA# 42400 www.gettingairborne.com
"Those are my principles. If you don't like them, I have others." - Groucho Marx
       Post #: 13
Brass Tubing - 2/12/2003 12:23:05 AM
big max 1935
Status: offline
Just a short tip, I buy a 1/8" copper compression fitting sleeve & solder it on the tubing leaving about 1/8"of tube sticking out of it. This will also fit 1/8" brass tube. That & a clamp you will never have a line slip off! Really think this would work great on pressure smoke systems, you know how messy that smoke oil is! >>>>>>>>>>big max 1935 AMA 14958
       Post #: 14
Brass Tubing - 2/12/2003 2:28:30 PM
WORNBOOTS
Status: online
Usually small screw drivers have a groove around the handle, after inserting a solid line like string trimmer or solid wire I lay it in the groove of the size I want. My small craftsman pocket screwdriver works good for tank 90's
Dan Z
**Enjoy the Thrill of Flight' Become an R C Pilot**
*I enjoy building 70's Kits as originally produced--Dan Z
       Post #: 15
Brass Tubing - 2/12/2003 2:52:27 PM
Cactus.
Status: offline
might have been said but forget brass, drubro and the like should be banned from selling these tanks. every single one rots, wether you empty it or not, i had another break on my Cougar the other day, there was the tinyest gap showing. its not fuel in the tube, its something in the air in the tank.
i used snake outer to replace the brass, hot water bends the snake nicely.
look at my Cougar review to view pics on this [url]www.philsrcworld.fsnet.co.uk/cougarreview.htm[/url]
My half dead website www.philsrcworld.fsnet.co.uk new site coming soon.
Redruth & District model flying club www.rcflye
       Post #: 16
