RE: Jensen Ugly Stick Build
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Scratch Building, Aircraft Design, 3D/CAD >> RE: Jensen Ugly Stick Build Page: <<   < prev  13 14 [15] 16 17 18 19 20 21 22   next >   >>
Login
RE: Jensen Ugly Stick Build - 3/24/2008 12:33:22 PM
Mustang Fever
Status: offline
Lookin good, Sean.
I flew mine last weekend in St. Louis. It's my favorite "relaxed flight" bird.
_____________________________
Bob Hunt
(in reply to Redwulf__34)
       Post #: 351
RE: Jensen Ugly Stick Build - 4/11/2008 9:17:35 PM
Redwulf__34
Status: offline
Good to hear from you Bob! I wondered where you've been!
I got tied up with some work related junk and slowed up a bit. I'm hoping to finish up this weekend and work on getting the engine running. All I have left is to install the fuel tank, main gear and she will be ready to fly.
The engine has been sitting for about 25+ years. It was a beautiful running engine when I was flying. I always pulled the glow plug and put in a drop or two of oil when I stored them. I'm sure I did that. I notice she doesn't have much compression right now. Any thoughts on what I should do? Will it get compression when I get some fuel in it and work on getting it running? Or should I tear it down and look it over?
Sean
(in reply to Mustang Fever)
       Post #: 352
RE: Jensen Ugly Stick Build - 4/11/2008 9:49:50 PM
Mustang Fever
Status: offline
Sean:
Is the thottle wide open when you're trying it?
You might want to put some more oil in the glow plug hole, and through the backplate into the crankcase, and just turn it over a bunch of times without the plug in it. It may be that castor oil gum on the cylinder and piston are making it sticky, so it won't "pop" like they usually do. If ordinary lube oil doesn't work, try spraying some WD-40 in there. It will dissolve most nasty stuff and won't hurt anything.
The week after St. Louis I took mine to the "Jersey Coast Sport Fliers", another club I belong to, and passed my pilot's test. The old Stick made me look good, even when she ran out of fuel just after the trim test, and the flaps helped me to make a decent deadstick, which is also part of it.
Bob Hunt
       Post #: 353
RE: Jensen Ugly Stick Build - 4/12/2008 3:52:00 AM
oneaew@msn.com
Status: offline
hi all you ugly stick builders here are some pictures of mine > flew it last sat> went right off the drawing board> real nice allen
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 354
RE: Jensen Ugly Stick Build - 4/12/2008 4:55:19 AM
Mustang Fever
Status: offline
I like your color scheme, Allen
If I had it to do over, I would have put my tail feather servos in the back like you did. Mine came out so nose heavy. You don't want to know how much lead is in it's tail.
Bob Hunt
(in reply to oneaew@msn.com)
       Post #: 355
RE: Jensen Ugly Stick Build - 4/12/2008 10:39:13 PM
oneaew@msn.com
Status: offline
all my planes are the same color> it is very easy for me to see>wish they still made the kit> i have not built one from the start in 40 yrs> its so easy to fly hoe everyone enjoys theres>also the nose gear has a servo>a y connector to the rudder> have fun allen
       Post #: 356
RE: Jensen Ugly Stick Build - 4/14/2008 6:28:33 AM
skylarkmk1
Status: offline
Lazer Works has the Ugly Stick (Jensen) Wingspan: 59 in., .40/.60 2-stroke $50.05 under the RCM section http://lazer-works.com/rcm.html . You can also get the Midwest Giant Sweet & Low Stick Wingspan: 89 in. Quadra 35 size gas $108.64 and the Midwest Das Little Stick Wingspan: 46 in. 19/32 2-Stroke $37.43 at Lazer Works under the Misc. Category http://lazer-works.com/misc.html
< Message edited by skylarkmk1 -- 4/14/2008 6:36:11 AM >
John F Howard (aka skylarkmk1)
AMA 10955, WACO Brotherhood #26, AWC, NWC
       Post #: 357
RE: Jensen Ugly Stick Build - 4/14/2008 12:25:10 PM
Redwulf__34
Status: offline
Very nice Allen. I''ve not had any time at all to work on mine. Hopefully I can get her finished up this week yet. Although the weather went south here in the south. Cold and windy so I guess I''ll have a little time.
Bob, I''ve had the throttle in various settings while turning it over. There is a "little" pop there but not much. There just isn''t much compression. I''m gonna get some more oil down in it and pull the back plate off like you suggested. If I don''t get any I''ll try some WD-40 then. There isn''t much pop or compression.
Sean
(in reply to skylarkmk1)
       Post #: 358
RE: Jensen Ugly Stick Build - 4/18/2008 8:15:34 PM
Redwulf__34
Status: offline
Still no time to get any work done! I'm so darn close! It's so nice here. 80+ today. I may head to the flying field tonite. Just to watch others have fun!!! Maybe it will motivate me to stay up late or something. I'm going to take some vacation next week. That should help me finish up.
Sean
       Post #: 359
RE: Jensen Ugly Stick Build - 4/24/2008 1:10:23 AM
Redwulf__34
Status: offline
I pulled the plug and sprayed a little WD40 in there and I've got some compression back. Nice pop too. But, I notice the top of the piston head was "black" with gunk. Do you think I should tear this thing apart and give it a good cleaning? I've got decent compression now.
Thoughts? I'm about ready to fire it up. I'm off on vacation the rest of the week so I intend to finish this girl up.
Sean
       Post #: 360
RE: Jensen Ugly Stick Build - 4/24/2008 1:33:23 AM
Mustang Fever
Status: offline
Sounds like you cleaned off some old gummed up castor oil. Instead of taking it apart, I think I'd repeat the WD 40 treatment until the gunk subsides a bit.
Bob Hunt
       Post #: 361
RE: Jensen Ugly Stick Build - 4/24/2008 10:00:33 PM
Redwulf__34
Status: offline
Well other than a few "un-necessary" aesthitic items I'm ready to go!!!!! I'll probably try getting the engine to run before going out to the field.
I had bought "large" fuel line and drilled the firewall before trying it. It was really too big for the "nipple" on the muffler. So I went back to the medium line. My holes in the firewall are just a tad too big now. I can use the larger diameter fuel line on the carb so I have one hole that is a little big. Would you guys worry about it? Should I try to fill it somehow to keep fuel out? The compartement has been fuelproofed.
I'll try to post up some pics tomorrow of my radio installation. If I build another I'll do a few things different but it's gonna fly!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Sean
       Post #: 362
RE: Jensen Ugly Stick Build - 4/24/2008 10:02:33 PM
Mustang Fever
Status: offline
Go knock a hole in the sky, flyboy.
Bob Hunt
       Post #: 363
RE: Jensen Ugly Stick Build - 4/25/2008 5:05:03 PM
Redwulf__34
Status: offline
Thanks Bob!!! I'll hope to knock holes in the sky and not the ground!!!!!!!!
Here are a couple shots of the radio installation.
I also still have my first radio. Anyone old enough to recognize this? I still like this radio. The sticks have a much nicer feel than any new radio I've ever tried. Even my now old Futaba that replaced this one. If I thought the frequencies that it used were still good, I may buy batteries and use it again!!!
Sean
Click for fullsize
Click for fullsize
