RE: Jensen Ugly Stick Build
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Scratch Building, Aircraft Design, 3D/CAD >> RE: Jensen Ugly Stick Build
Page: <<   < prev  16 17 18 19 20 21 22 23 [24] 25   next >   >>
Login
RE: Jensen Ugly Stick Build - 2/19/2009 10:06 PM
flying pastor
Score: 100
Last Login: 9/29/2009
Status: offline
Sean, the build thread I was thinking of was by hammerd. Thanks for the info on the underfin. I made mine out of three laminations of ply and the centre one is let into the bottom of the tailplane so I think that it will stay put. Our weather has been somewhat bizarre. Two days before the maiden we had 4ins of snow, when I maidened it was quite warm and sunny and today has been about 10 degrees C. Spring is on the way!! Incidentally do you think an OS 46 FX would fly a DUS. I have just come into one of these from a deceased modellers estate and it has only about 6 flights on it and is I believe quite a hot motor.
All the best to you stick builders and fliers. Chris. UK.
p.s. in the near future my DUS will hopefully be flown by the club "hotshot". I will be interested in his comments on its flying performance.
Hide Signatures
(in reply to Nergall)
       Post #: 576
RE: Jensen Ugly Stick Build - 3/21/2009 9:24 PM
flying pastor
Score: 100
Status: offline
Just a short update. 8 flights completed now (1 hour total approx). All controls set up and harmonised to my satisfaction and power system is working flawlessly. Last flight was by the club hotshot. After I had reminded him it was not a fun-fly but a sport aerobat he proceeded to fling it around the sky and was surprised and full of praise for the way it flew. The problem I have is what to build next? It needs to be for 60 to 90 power and a sport aerobat, possibly low wing. Meanwhile I have a great model to fly and enjoy.
Chris UK.
Hide Signatures
(in reply to flying pastor)
       Post #: 577
RE: Jensen Ugly Stick Build - 3/22/2009 12:22 AM
Mustang Fever
Score: 112
Last Login: 11/8/2009
Status: offline
Nice going, Chris
I good, easy to fly aerobat is the Super Kaos. The plans are available through RCM Magazine website.
_____________________________
Bob Hunt
Hide Signatures
       Post #: 578
RE: Jensen Ugly Stick Build - 3/22/2009 11:25 AM
matadco
Score: 100
Last Login: 10/28/2009
Status: offline
You can order an Utter Chaos through Bluejay hobbies in Nebraska. I just finished one but I added retracts. Had the 40 size Chaos from Bluejay which was a great little bird until let someone in the club crash it for me.
Hide Signatures
(in reply to Mustang Fever)
       Post #: 579
RE: Jensen Ugly Stick Build - 3/22/2009 4:19 PM
Mustang Fever
Score: 112
Status: offline
Here's the url for Bluejay: http://www.bridiairplanes.com/
I ended up purchasing a short kit for the Super from these guys: http://lazer-works.com/misc.html
The super is near the bottom, and now they're calling it the "ultimate", as they've redesigned the fuse, so the original RCM plans may or may not work with it. I'm glad I got mine before they changed it.
Bob Hunt
Hide Signatures
(in reply to matadco)
       Post #: 580
RE: Jensen Ugly Stick Build - 3/22/2009 4:20 PM
flying pastor
Score: 100
Status: offline
Bob, thanks for the reply the super kaos is just the type of model that I am looking for.
Matadco, thanks for the info but shipping to the UK can be expensive. I am also looking to plan build for my project for next winter.
All the best.......Chris UK.
Hide Signatures
       Post #: 581
RE: Jensen Ugly Stick Build - 3/22/2009 5:06 PM
Mustang Fever
Score: 112
Status: offline
Chris: Here's the url for the plans: http://rcmmagazine.com/store/store-plans-catalog-tem.html?item=plans:pl-526&sid=0001LfVNolYXhwskXw3e3h9
The build article is available online at the RCMM website too. You click Requested Articles, then Construction, which you usually have to do a couple times to get in, then sign in with newuser and imaa (which they show you) , then it's plan #526 as you go down the list. Sometimes the article won't load properly, but eventually will.
You'll love the way a Kaos flies. They'll do about anything you're willing to try except hover, and land easier than any trainer I've ever had. When I build mine, I'm going to use an OS 55AX, but given the difference in engines between then and now, a 45-50 would probably be more than enough.
Bob Hunt
Hide Signatures
       Post #: 582
RE: Jensen Ugly Stick Build - 3/22/2009 5:13 PM
Redwulf__34
Score: 100
Status: offline
Some great plans hanging around here too. http://www.profili2.com/eng/plans.asp Type in Kaos and you'll get some drawings there. If you like a scratch build.
I always wanted to build a kaos. Never got around to it. Working on a small corsair now. Going to be electric park flyer!
Sean
< Message edited by Redwulf__34 -- 3/22/2009 5:14 PM >
Hide Signatures
       Post #: 583
RE: Jensen Ugly Stick Build - 3/26/2009 7:42 AM
jrcaster
Score: 100
Last Login: 10/3/2009
Status: offline
I got the plans yesterday, and ordered about a half a tree worth of balsa today. I plan on doing a few changes to this to make it more modern.
I am swapping out the formers from balsa to 1/8 light ply, Aileron stock for the ailerons and elevator instead of 1/4 inch flat stock, Wing bolts, and changing the hatch to get rid of the rubber bands, and changing from 1/4 balsa for the sides and going to 1/8 inch balsa and 1/8 inch light ply doublers bach to the rear of the wing saddle. Also building with no dihedral. I am thinking of building the wings with sheeted leading edge and sheeting the center section too, and adding shear webs.
Other things that are getting changed are to not cut out the control horn area and adding plywood there. I plan on reinforcing that by poking a pin in those areas and using thin CA.
Kit building is the fine art of persuasion. Please line up.
Hide Signatures
(in reply to Redwulf__34)
       Post #: 584
RE: Jensen Ugly Stick Build - 3/26/2009 10:04 PM
flying pastor
Score: 100
Status: offline
jrcaster. I wouldn't change things too much. Wing, zero dihedral seems to work well and shear webs are always a good idea. I sheeted the centre section but not the leading edge and it seems fine. I kept the balsa formers and the 1/4" balsa sides but I put in 1/32" ply doublers from the firewall to just behind the wing trailing edge. I am quite happy with wing bands but can understand anybody changing to a bolt on wing. Enjoy the build...and the flying.
Chris.....UK.
Hide Signatures
(in reply to jrcaster)
       Post #: 585
RE: Jensen Ugly Stick Build - 3/27/2009 7:51 PM
8178
Score: 100
Last Login: 11/6/2009
Status: offline
I prefer just a smidge of dihedral to eliminate the drooped wing illusion straight wings cause.
Hide Signatures
       Post #: 586
RE: Jensen Ugly Stick Build - 3/27/2009 9:00 PM
Redwulf__34
Score: 100
Status: offline
Hi Jrcaster!
Good to hear more sticks are being built! She is a great bird! I agree about the rubber bands. Get rid of em!!!!!! I'm not sure how much other redesigning she needs. Sounds like you know what your doing though so have at it!
My wing is flat no dihedral. I wouldn't build it any other way personally. Much easier for starters. I just built the whole wing in one piece. Check out how I did myhatch post #115. I'm real happy with it.
Post your progress. I like seeing them!!
Sean
Hide Signatures
(in reply to 8178)
       Post #: 587
RE: Jensen Ugly Stick Build - 3/27/2009 9:47 PM
Nergall
Score: 100
Status: offline
I agree the wing looks best with just a tad bit of dihedral. OTOH, probably doesn't knife edge as well that way.
My hatch version: (Post 40-47)
http://www.rcuniverse.com/forum/fb.asp?m=8539594
Copied this from a previous Sweet Stick. The wing holds it in place, so there are no screws, dowels or whatever to add. You just need a bit of frame to keep it from sliding side to side.
Hide Signatures
       Post #: 588
RE: Jensen Ugly Stick Build - 3/27/2009 9:57 PM
Redwulf__34
Score: 100
Status: offline
Hi Nergal!
That's another great way to hatch too. I built a sweet stick years ago. It had a hatch that way too. I was originally going to build my DUS that way too. The only reason I changed my mind was the nose gear. On my Sweet Stick it was a pain in the uh huh to get to the nose gear with the balsa up front. I wanted a clear unobstructed path to the nose gear and the engine mounting stuff.
Your build looks great. I'll be tagging on there to see the progress!
Sean
Hide Signatures
       Post #: 589
RE: Jensen Ugly Stick Build - 3/27/2009 10:05 PM
Nergall
Score: 100
Status: offline
Gotta agree on the nose gear!
What made it especially bad was I had built in some rails to hold the fuel tank up. I'm thinking of building a removable "table" of sorts for that this time.
Of course, if had just mounted it on the outside instead...
Hide Signatures
       Post #: 590
RE: Jensen Ugly Stick Build - 3/28/2009 8:58 PM
jrcaster
Score: 100
Status: offline
I plan on putting the nose wheel on the outside, so the hatch will not be needed, so I plan on increasing the hight of the firewall and sides by 1/8 inch and using a 1/8 inch sheet for the hood instead of 1/4 inch. That will also give me 1/8 inch more meat on former 2 so I can run dowels in there for wing attatchent. Since the wing is not sunk down into the fuselage, I can't run the dowels straight through the leading edge like most bolt on wings and I will go to my Sig Kavalier plans to be able to design an offset mount.
I know that I am playing with a lot of different ideas on this, some areas I am decreasing weight, and other areas I am adding weight. I remember reading in one of the early posts that the wing was still flexable (twist) after it was built up. Maybe the covering will tighten that up, but I know that D tube construstion will take a lot of the flex out of it.
Hide Signatures
       Post #: 591
RE: Jensen Ugly Stick Build - 3/28/2009 9:01 PM
jrcaster
Score: 100
Status: offline
As far as knowing what I am doing, When I go for the maiden and the plane explodes at the end of the runway... we will know then.
Hide Signatures
       Post #: 592
RE: Jensen Ugly Stick Build - 3/28/2009 10:24 PM
flying pastor
Score: 100
Status: offline
jrcaster. Have a look at "ugly stik build from internet plans" for one way of front wing attachment although this needs different centre ribs. You could also fit the front dowels so they fit below the leading edge. Regarding wing twist, one well known British designer (Peter Miller) has fitted shear webs on BOTH sides of the main spars on some of his models and says that this improves matters considerably. When the wings are covered they appear to be very twist resistant.
Chris....UK
Hide Signatures
       Post #: 593
RE: Jensen Ugly Stick Build - 3/29/2009 7:13 AM
jrcaster
Score: 100
Status: offline
I tried to check it out but seems the links to all the pictures were broken.
I have the Sig Kavalier, and the wing is joined by lowering the dowels below the leading edge. That is why I mentioned that in the previous post.
As far as the box construction, I didn't think of that. That is similar to the Fokker DR1. I chose the D tube construction for two reasons, I am familiar with it, and it will reduce the leading edge turbulance created by the forward sub spars and pockets created then covering the wing. The D tube may be heaver than the box or the original versions, but the smoothness will make the wing more rugged, and increase the top speed a little.
I don't expect this plane to be as fast as the SuperSportster, but I want it to be a little more efficient than what was designed back in the 60's
< Message edited by jrcaster -- 3/29/2009 7:19 AM >
Hide Signatures
       Post #: 594
RE: Jensen Ugly Stick Build - 4/3/2009 4:59 AM
jrcaster
Score: 100
Status: offline
I got my wood today. Now I just have to finish covering on my SuperSportster and clean off the table. Then it will be time to start making templates, and making sawdust.
Hide Signatures
       Post #: 595
RE: Jensen Ugly Stick Build - 5/9/2009 11:16 PM
MasterAlex
Score: 105
Last Login: 10/29/2009
Status: offline
Sean
I know you're onto bigger and better now (F4U), but I thought I'd post a picture or two of my scratch built stick. Your build inspired me to give it a shot and honestly, this turned out better than I had hoped. This was my first scratch build and I definitely will do another. I plan to maiden this tomorrow. For those interested, this was built from plans drawn by Jason Nimier of RCU.
-MA
Click to see fullsize image.
Click for fullsize
"What you do off the job is determining factor in how far you will go on the job" - how appropriate for us RCers!
Hide Signatures
       Post #: 596
RE: Jensen Ugly Stick Build - 5/10/2009 12:33 AM
MasterAlex
Score: 105
Status: offline
... a couple more - the first image was too large to allow other photos on the same message, sorry about that
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to MasterAlex)
       Post #: 597
RE: Jensen Ugly Stick Build - 5/10/2009 1:16 AM
Redwulf__34
Score: 100
Status: offline
WOW! Looks great Alex. I love your scheme. You'll love how she flies too. I have been pretty busy here. The Corsair has made no progress lately.
I haven't had the stick out either. Things have been so busy lately. I'm hopeful to get the DUS back in the air within the next few weeks. I'll be joining a new club this year. Last year I was a member at a nice club but it was 30 minutes away. That made it hard to get energized to go flying. This year I'll join the local club. It's 5 minutes away. It is a bigger club and not as friendly a bunch of guys but it's close.
Cant waite to hear how the maiden goes!
Sean
Hide Signatures
       Post #: 598
RE: Jensen Ugly Stick Build - 5/10/2009 1:39 AM
Nergall
Score: 100
Status: offline
Here's another one!
Hoping to maiden next week as well.
More details here: http://www.rcuniverse.com/forum/fb.asp?m=8754729
Click for fullsize
Hide Signatures
       Post #: 599
RE: Jensen Ugly Stick Build - 5/10/2009 2:16 PM
MasterAlex
Score: 105
Status: offline
quote:
ORIGINAL: Redwulf__34
Thanks Sean! I got the idea from your thread - the idea to go against the "traditional" Stick markings. I flew a .40 Stick for years and hated when someone else showed up with the exact same plane. I looked through historical planes and really anted to do a losenge pattern and make it really look like a WWI German plane. Something like the 1st picture below (can't remember, this might have come from you ...). Anyway, I couldn't bring myself to take out a second mortgage for the losenge covering - maybe I'll do it someday. I stumbled on a RCU ad one day for a Nitro Planes DR-1. The covering was unique (Picture 2), and served as the inspiration for my build. I doubt there'll be anything at the field resembling this stick . I also like it because there were once planes painted this way, so it makes it "feel kinda scale".
I'll let you know - wish me luck.
-MA
Click for fullsize
Click for fullsize
< Message edited by MasterAlex -- 5/10/2009 2:17 PM >
Hide Signatures
       Post #: 600
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
2.156RCU1
