Predator
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> ARF or RTF >> NitroModels Support >> Predator
Page: [1] 2   next >   >>
Login
Predator - 2/27/2007 1:22:29 PM
jfail1
Status: offline
I have sent e-mails, made phone calls etc. and NitroPlanes never responds. It seemed for awhile they were improving but I think they are going bad again.
Thier web site shows a Predator UAV that I am interested in purchasing and playing around with. They list two ARF's, one part number 212308 at $74.95 and another with no part number at $89.95. I cannot tell any difference between them other than the price. I have tried contacting NitroPlanes thru the normal methods as above. No response.
Maybe they will read this. I sure wish they would clear this up and I will order one.
< Message edited by jfail1 -- 2/27/2007 1:39:24 PM >
       Post #: 1
RE: Predator - 2/27/2007 4:40:13 PM
Glacier Girl
Status: offline
Hmmm, that is weird, I have the 63" camo version, one thing I did notice, neither of the two you mention, at least from the photos, has the upside down vertical stabilizer that mine has.
Must of changed the design. I like mine with the 3rd tail as I put a metal skid on it to keep the prop from hitting the ground on take offs. The way they are in the picture, you'll be grinding up a lot of props if your take off angle of attack is too steep.
Well if you ever get one you'll like it. Flies very well. I equipt mine with a hacked CVS vid camera.
_____________________________
"The Missing Man Formation"
Looking heavenward you cannot help but shed a tear...mornful...lonesome...a hole that screams out almost as loudly as the roar of the engines that pass over head.
(in reply to jfail1)
       Post #: 2
RE: Predator - 2/27/2007 4:59:36 PM
opjose
Status: offline
The cheaper unit does not have ailerons. The cheaper plane is controlled completely by V-Tail mixing.
The slightly more expensive unit was the one that was recently (and favorably) reviewed in the magazines.
Build em'', fly em'', crash em'' and build more.
(in reply to Glacier Girl)
       Post #: 3
RE: Predator - 2/27/2007 5:25:51 PM
jfail1
Status: offline
opjose
Thanks very much for the help. I will order the $89.95 one. I would have never figured that one out, thanks again
(in reply to opjose)
       Post #: 4
RE: Predator - 2/27/2007 5:27:58 PM
jfail1
Status: offline
Glacier Girl
Thanks for the info. If one reads the description you get the idea that the stab would be down but I thought they were actually referring to the REAL Predator. Hopefully it will have the correct stab. Thanks again.
       Post #: 5
RE: Predator - 2/27/2007 8:52:52 PM
nitroplanes
Status: offline
they are the same item in fact. 212308 can only be ordered if we accepted your offer thru RCU we do not have offer for now so please order $89.95.
John
Nitro Planes
       Post #: 6
RE: Predator - 2/27/2007 9:27:59 PM
opjose
Status: offline
Hi John;
The pictures and statistics for both planes are entirely different.
One is listed as a 4 channel model and the other as a 3 channel version.
The three channel version has no visible ailerons.
Please clarify.
Thanks.
(in reply to nitroplanes)
       Post #: 7
RE: Predator - 2/27/2007 10:16:09 PM
nitroplanes
Status: offline
http://www.nitroplanes.com/4eluavrqprra.html
http://www.nitroplanes.com/4eluavrqprra1.html Item (212308)
are same item.
http://www.nitroplanes.com/uav3arfbrelr.html
is the 3 channel one. longer wing span. Yes no alieron.
Thanks for pointing this out.
PS: opjose I should have your ultimte 120 cowl (if I remember correctly) send out this thurday or friday. Need any other parts?
quote:
ORIGINAL: opjose
Hi John;
Please clarify.
Thanks.
       Post #: 8
RE: Predator - 2/28/2007 12:25:20 AM
opjose
Status: offline
Thanks for remembering!
Just the cowl and canopy.
Beautiful plane btw. I posted my "pink" build on the other thread.
Can't wait to fly it.
I'm building my backlog of planes that I've purchased from you guys last year.
I still have five more to go!
       Post #: 9
RE: Predator - 3/1/2007 1:03:41 AM
jfail1
Status: offline
opjose
Can you tell me which magazine the review of the Predator appeared in. I am sure I saw it in the past but I can't find it to save my life.
John
       Post #: 10
RE: Predator - 3/1/2007 5:51:29 AM
opjose
Status: offline
Page 84 of this month's "Backyard Flyer".
       Post #: 11
RE: Predator - 3/3/2007 2:45:33 PM
jfail1
Status: offline
I started building mine last night. I was suprised at a few things on it. The wings are intended to be glued on and not removeable. If one did that it would be pretty tough to change an Aileron servo if it was required. I am going to try to figure out something to get around that problem such as cutting an access hatch in the bottom or top of the fuselage.
Also I see that no access holes are cut in the fuselage to route the servo wires into the fuselage although they are cut in the wing root. I am using HS-65 servos for the Ailerons they bottom out in the wing and I had to make small mounting blocks and glue them to the wing to avoid that problem.
I also see that holes are not drilled in the Elevator stabs for the steel pins that go into the fuselage even though they are present in the fuselage.
Seems like the manufacturer left out some details on this plane. Not a big deal for the price but kinda strange.
What flight configuration did you guys use, Elevons?, conventional Aileron/Elevators?
I fly off of a dirt runway and the lack of steering is of a little concern to me.
Any input would be appreciated on configuring the flight condition, building etc. Also the throws used would be valuable.
The article about the predator in Backyard Flyer is an absolute joke with no details of any kind and no mention of problems (such as the lack of holes for the Aileron servo wires) among many others. As per usual in the magazine reviews they say the plane is perfect so that manufactures will still advertise in thier magazine.
       Post #: 12
RE: Predator - 3/9/2007 4:30:52 PM
zaGURUinzaSKY
Status: offline
I ordered the balsa model of the predator 2 month ago, I received it with the a rudder fin missing (it's a v-tail), I wrote emails for 2 months, made 5 phonecalls, 3 from italy and 2 from California, 2 times I left a message in the answer machine but nobody have ever helped me.
The only time they wrote me something longer tha 3 words has been: " please send us a picture of the missing part" ahaha, picture of the missing part.
Today I sold for half price the model to a modeler and he'll probably build the missing part ( I have no skills to do that), so the Predator for me has been just a waste of money. Adios Nitroplane.
       Post #: 13
RE: Predator - 3/9/2007 6:28:05 PM
jfail1
Status: offline
I am ready to maiden mine tomorrow morning. I am curious about the lack of steering. Anyone got info on how it handles on the ground? Does it track straight on takeoff and landing or should I be ready for some pulling one way or the other? Any comments on flying it would be helpful also.
John
(in reply to zaGURUinzaSKY)
       Post #: 14
RE: Predator - 3/13/2007 3:55:30 PM
zaGURUinzaSKY
Status: offline
Even with a post in Nitro Support Forum, after almost a week ( and 2 months of emails and phonecalls) I don't have any news.
Improved customer service? This is not even legal I think. Think about it before u buy from them, as u can see also in this forum, sometimes customer support is unexisting, even when your product is useless. What's so difficult in answering a customer in your forum Nitro guys???????
       Post #: 15
RE: Predator - 3/13/2007 4:31:39 PM
opjose
Status: offline
quote:
ORIGINAL: zaGURUinzaSKY
I wouldn't expect a response in a forum to get something resolved. There are other avenues.
I though you already stated "adios"?
