Heli-max axe cp
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> Helimax >> Heli-max axe cp
Page: [1]
Login
Heli-max axe cp - 2/27/2007 6:45:22 PM
cavwrench
Status: offline
Hay guys and girls. I got my axe cp on friday, i flew it a couple time over the weekend and i was not very impresed. I have flown helli's for about two years and got pretty good bu have not flown in like two years. So i got the axe and though it would be cool. the first couple flights were not that good. It seemed like all i was doing was trimming it out. Not really bad though. Anyway i came on here last night and found some good info. To start i took the main blades of and snugged down the blade grip screws, Then i removed all links to swash plate and lubed those with a associated white grease. Then i measured the paddles and found one was not as far on as the other one. So i took of both paddles and installed another collar on each side and reinstalled the paddles to the same measurement's on both sides. I then did a test flight and it shook kind of bad. I began to adjust the collars on flybar to get rid of shake as much as i could. Let me say this thing almost fly's like a dream now. I was so impressed with the differance and it took me like a half hour to do all that work. I also then tried my thunder power 11.1 910 mah li-po battery and also made a big change in the helli's attitude, not only in power but also how it flew. I again had to trim it but can fly in my family room with no problem. This thing is not to bad after all but let me know what you guys think about doing the servo cahnge. Is it REALLY worth it? Let me know what you guys have come up with. Thanks
       Post #: 1
RE: Heli-max axe cp - 2/27/2007 7:06:49 PM
sammy64
Status: offline
Yes the servos really make a difference .. HS55 Servos ... another thing that helps a lot is the Gyro install no more flying the tail .. swap that TX unit
(in reply to cavwrench)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.344RCU2
