BME 115 Any Field Reports?
Tower Hobbies
Logged in as Guest
  Printable Version
RCGF 20cc Gasoline Model Airplane Engine
Seller:  jewillis2
Details:   $214.88   |  1/6/2009   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> BME 115 Any Field Reports?
Page: [1] 2 3 4 5 6 7 8 9 10   next >   >>
Login
BME 115 Any Field Reports? - 2/28/2007 4:31:38 PM
Pontiac_40
Status: offline
The folks who own thw BME 115, could we get some latest field reports, videos and comparisons. Any feedback would be appreciated.
_____________________________
Fly and let fly
       Post #: 1
RE: BME 115 Any Field Reports? - 2/28/2007 6:43:18 PM
Tired Old Man
Status: offline
RTK has one of the first 115's that hit the streets. I was given the opportunity to fly it in his Comp Arf 330. Extremely strong, good bottom and middle, with a fine transition. It's the first engine I've ever seen where a 2.6 meter (35%) plane would transition from maximum level speed into an immediate vertical line and never slow down. Scared me some actually because I wasn't sure the wings would stay on in the pull from horizontal to vertical. Absolutely no shortage of power on stock mufflers.
I don't have mine mounted on anything yet. If the weather goes to good then we'll be flying RTK's again this weekend.
Flyinrazrback has done quite a bit of flying with his and seems to be very happy with it. He's posted quite a bit of info regarding rpm counts and props used and so far it's knocked the rest of the 100cc class engines in the dirt.
If you can''t fix it with a hammer, you have an electrical problem.
(in reply to Pontiac_40)
       Post #: 2
RE: BME 115 Any Field Reports? - 2/28/2007 9:49:32 PM
Pontiac_40
Status: offline
Silversurfer, thanks for the responce. That sounds pretty good. I am in the process of putting together my comp-arf 2.6 yak and would love to go with the BME 115. I had already purchased a DA-100 but the BME 115 sounds real good---Less Weight and seems like more power. I wonder who makes some good header and pipes for this beast? If you could post some video of RTK's 2.6 in action, that would be very cool!
Fly and let fly
(in reply to Tired Old Man)
       Post #: 3
RE: BME 115 Any Field Reports? - 2/28/2007 11:34:15 PM
RTK
Status: offline
Silversurfer has a comp-arf Yak and a 115 sitting at home waiting to be assembled. I am going to have to start pushing him to get it done.
I don't have any video of the 115 in action yet. But as SS had mentioned, when it was on my comp-arf extra it would really hall a$$. It would go vertical just as fast as horizontal. For some reason I kept trying to turn that extra into a race plane, I just love too hear that prop rip. I currently have it in a WH Sukhoi, but I don't think I will be doing any race circuit type of flying.
The 115 runs just as smooth as any other well tuned engine but has the weight and power advantage. There are a few videos of it in action in a WH Sukhoi on the DOD web site. Kyle "the alien" really knows how to fly.
As for pipes or cans give Keith a call he has run some, so that would be where I would start. Flyinrazrback was going to try some E composite pipes, cool pipes that weight nothing, on his but I do not know if he has yet or not.
Ralph
< Message edited by RTK -- 2/28/2007 11:43:17 PM >
       Post #: 4
RE: BME 115 Any Field Reports? - 3/1/2007 12:40:56 AM
Tired Old Man
Status: offline
No pressure here I see
Pontaic, I selected the 115 for the same plane. I'm certain you be more than happy with the combination.
< Message edited by Silversurfer -- 3/1/2007 12:42:08 AM >
(in reply to RTK)
       Post #: 5
RE: BME 115 Any Field Reports? - 3/1/2007 6:12:22 PM
Pontiac_40
Status: offline
Thanks SS and RTK, can't wait to get this baby on my yak. I did speak with Keith and he said the next batch of the 115's should be here in mid March, got my name on the list. The ES composite pipes are way cool, I will have to sell my my MTW cans and flex headers and also my DA-100. SS, I think you are right, I will be a happy camper with this puppy in the nose of my Yak .
Fly and let fly
       Post #: 6
RE: BME 115 Any Field Reports? - 3/1/2007 8:39:30 PM
flyinrazrback
Status: offline
Pontiac, the 115 on the yak with ES pipes will be phenomonal. When you order the ES pipes ask for him to set the baffle at 18.5" in the pipe so you can run a 12" header. Typically he sets the baffle at 16.5" and you have to run a 14" long header, but those can be hard to find so setting the internal baffle at 18.5 allows the same tuning but a 12" header. Should be an awesome setup. I loved my 115. I had the same 2.6 yak with a 3W 106CS and KS tuned pipes and it was just nasty sick on power, the lighter 115 setup with pipes will have to be seen.
"You'll get your chance smart guy!"
       Post #: 7
RE: BME 115 Any Field Reports? - 3/1/2007 9:36:19 PM
Tired Old Man
Status: offline
You say "loved" as in past tense. ?????
(in reply to flyinrazrback)
       Post #: 8
RE: BME 115 Any Field Reports? - 3/1/2007 10:13:41 PM
RTK
Status: offline
I thought you were supposed to be working on that Yak..........................
       Post #: 9
RE: BME 115 Any Field Reports? - 3/2/2007 12:34:58 AM
Tired Old Man
Status: offline
Sheesh, I haven't even got the Edge off the bench yet.
(in reply to RTK)
       Post #: 10
RE: BME 115 Any Field Reports? - 3/2/2007 2:44:52 AM
Pontiac_40
Status: offline
Thanks for the tip Flyinrazrback! So when do you plan to have the 115 mounted on your Yak? Please be sure to share some photos of your Yak. Man, sounds like a killer setup!!
Fly and let fly
       Post #: 11
RE: BME 115 Any Field Reports? - 3/4/2007 7:34:47 PM
Pontiac_40
Status: offline
Silversurfer, let us know when you start on your Yak. Are you going with the ES pipes?
Fly and let fly
       Post #: 12
RE: BME 115 Any Field Reports? - 3/5/2007 3:45:16 AM
RTK
Status: offline
Pat will be running stock exhaust from BME. We flew my 115 in a 25lb WH Sukhoi today on stock exhaust, there was no shortage of power. Rcblimpro (Shaun) ran the plane thru bits and pieces of the unlimited IMAC sequence. I believe he commented that it had a lot of power. If you put that Yak on ES pipes it would have un-real power.
       Post #: 13
RE: BME 115 Any Field Reports? - 3/5/2007 4:48:51 AM
Tired Old Man
Status: offline
Don't need no stinkin' pipes. RTK scared shat out of me today when he gassed on his when I was holding it. I didn't think I had a good enough grip on it and had to yell at him to back it down. Stupid, stupid, I repeat, stupid!! thrust and power. Flew that 35% Sukhoi all day and only once was max throttle used, and only briefly. In level flight I didn't think that plane would go that fast, and I was the one that did the prototype report! There has to be something wrong with 10 foot take off rolls...
25 pound plane and unlimited vertical? Naw, more like ballistic with stock pipes.
I'll be starting on that Yak sometime this week between flying my new Edge, RTK's Sukhoi, and a little convalescing.
< Message edited by Silversurfer -- 3/5/2007 5:02:43 AM >
(in reply to RTK)
       Post #: 14
RE: BME 115 Any Field Reports? - 3/5/2007 4:57:33 AM
Joe Kelley
Status: offline
I had a chance to hold one of these 115s yesterday and was very impressed. The weight is noticably light. Can't say I've gotten to fly one but I won't pass up the chance. It weights 1.6lbs less that a DA100? Seems very light.
joe
