RE: BME 115 Any Field Reports?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: BME 115 Any Field Reports?
Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
RE: BME 115 Any Field Reports? - 3/28/2007 1:49:24 AM
krayzc-RCU
Status: offline
talk about some long bolts sticking out of that motor mount
_____________________________
smooth as silk!
(in reply to Tired Old Man)
       Post #: 51
RE: BME 115 Any Field Reports? - 3/28/2007 1:59:41 AM
Pontiac_40
Status: offline
Thanks for the info and pics! Is there a reason for having the prop at least 2 inches form the cowl? Also what type of wood are you using for the stand-offs?
Fly and let fly
       Post #: 52
RE: BME 115 Any Field Reports? - 3/28/2007 3:24:00 AM
Tired Old Man
Status: offline
The bolts are hardened 10-32 x 4". They have to go from the engine, through the mounts, through the firewall, and through a 1/8" x 1-1/4" ply donut that will be inside the firewall. I prefer the long bolts to having a short one at each end of a threaded aluminum tube. Now if the middle structure (the standoffs) were a solid combined structure then I would go for it. Manufacturers can make a tube stock aluminum standoff REAL cheap, but not one milled from a solid block, and with longer standoffs a solid structure would be much, much better than individual tubes.
The mount material is a hardwood, oak, I believe in this case. It was obtained from the dumpster behind a custom cabinet shop. They throw all kinds of neat wood away. You should see some of the finish grade thin plywood scraps they toss. Usuable size pieces, too!
The primary reason for the forward positioning is to improve efficiency. Placing the prop up against a big round cowl sorta wipes out what the prop is supposed to do at the area against the cowl. Lot's of turbulence between the prop and the engine. Moving it forward an inch or more cleans up the air a little and improves thrust a bit. For the purists, yes, I'm aware that a propeller does not create thrust, but lift relative to the face of the propeller blades.
Secondary reason is that the 2.6 Yak 55 can end up tail heavy real easy. Using a light engine helps make that happen unless you plane for the lighter weight by positioning equipment more forward. In this case the additional forward distance will almost offset the lower engine weight and still look relatively scale. Anyone ever see the propeller of a full scale Yak or Sukhoi up tight against the cowl? They are not.
If you can''''t fix it with a hammer, you have an electrical problem.
(in reply to Pontiac_40)
       Post #: 53
RE: BME 115 Any Field Reports? - 3/28/2007 4:28:30 PM
Pontiac_40
Status: offline
Again, thanks for the detailed info. That's what I thought. I was thinking of using 1"-1.5"(diameter) hardwood dowels wrapped in fiberglass and epoxy or wrapped in Kevlar string and epoxy then drilling them through.
Fly and let fly
       Post #: 54
RE: BME 115 Any Field Reports? - 3/30/2007 4:30:46 AM
dbcaster
Status: offline
Well I can give another great report for Keith's service. I sent in my 115 for a carb issue. Two days later the engine is on its way back to me with an new carb and a new reed cage.
< Message edited by dbcaster -- 3/30/2007 4:58:32 AM >
       Post #: 55
RE: BME 115 Any Field Reports? - 3/30/2007 4:38:48 AM
AmpAce
Status: offline
What is the thing with the shortened riser? It sounds like something I could use on the application I am considering, since I antcipate having limited vertical clearance for the carburetor.
Is it supposed to affect the way the engine runs? About how much shorter is it?
Thanks for any information.
AmpAce
(in reply to dbcaster)
       Post #: 56
RE: BME 115 Any Field Reports? - 3/30/2007 4:48:50 AM
dbcaster
Status: offline
< Message edited by dbcaster -- 3/30/2007 4:57:12 AM >
(in reply to AmpAce)
       Post #: 57
RE: BME 115 Any Field Reports? - 3/30/2007 5:31:35 AM
krayzc-RCU
Status: offline
what does the reed cage do?
smooth as silk!
       Post #: 58
RE: BME 115 Any Field Reports? - 3/30/2007 5:39:29 AM
Tired Old Man
Status: offline
The reason for the shorter insulator block is because people did not like or want the carb hanging out the bottom of the cowl. Can't say I blame them. The new shorter one makes no change in performance. I presume that was what was meant by "reed cage".
Krayzc,
A reed cage keeps all the reeds from getting out and lost at night. Buggers are the devil to find once they get out. You see all the reeds in the cages are usually adolescent male reeds, and you can imagine how their hormones must be raging to make that 115 run so strong. If you have one female reed in the cage the engine misses a lot because all the males will be fighting over her. They will always go looking for female reeds if given the opportunity.
(in reply to krayzc-RCU)
       Post #: 59
RE: BME 115 Any Field Reports? - 3/30/2007 6:38:27 AM
Herby 1
Status: offline
You need to go back to the sand box
       Post #: 60
RE: BME 115 Any Field Reports? - 3/30/2007 8:16:26 AM
Tired Old Man
Status: offline
Soon, I think.
(in reply to Herby 1)
       Post #: 61
RE: BME 115 Any Field Reports? - 3/30/2007 1:04:21 PM
dbcaster
Status: offline
Yes forgive me I meant insolator block. It was late at night and I could not think of what to call it. It did bring about your amusing definition of a reed cage though.
       Post #: 62
RE: BME 115 Any Field Reports? - 3/30/2007 1:30:50 PM
krayzc-RCU
Status: offline
smooth as silk!
       Post #: 63
RE: BME 115 Any Field Reports? - 3/30/2007 5:13:47 PM
Tired Old Man
Status: offline
Thanks! It gave me the opportunity to have some fun with it
       Post #: 64
RE: BME 115 Any Field Reports? - 4/3/2007 3:00:37 AM
Tired Old Man
