RTK
CA, USA Status: offline
Pat- I only have a few flights on mine, I'm not jumping the gun yet. But it did work the first time out. There might also be a forth way soon. Altivillan-- You can turn up the low needle a lot and it will not muddy up the low/mid range causing the dreaded burble when rolling. The problem is the high circuit is feeding WAY too soon. That is what is screwing up the low/mid range, lean the high enough and it subsides. Or at least for me, but if you fly much WOT it gets hot quick! and you know me. So,,,,, You richen the low needle to compensate for the leaning of the high which keeps you from melting your canister couplers. Well, it still will lean on the top with out a mod. Counter intuitive, ain't it I haven't counted the turns on the three needle carb yet. All you really have to do is visually see how the low is cranked out and the high (now mid) is turned almost all the way in. The new high is the old governor. That is what I like about the three needle carb. It "should" be infinitely adjustable for any engine made. Edited for dbcaster--You are correct, with the "stock" WB carb you will either be too lean on the top and ok in the low/mid OR you will be rich/dieing in the low/mid and fine on the high.
< Message edited by RTK -- 10/4/2007 11:54:51 PM >
