RE: BME 115 Any Field Reports?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: BME 115 Any Field Reports?
Page: <<   < prev  32 33 34 35 [36] 37 38 39 40 41   next >   >>
Login
RE: BME 115 Any Fi... - 10/15/2007 6:11:07 PM
Steve
Status: offline
Ron's plane just has the two needle carb with the midrange mod,,smaller port tube,, and a stuffed reed block. Its been working very well the last few times out. Even slow inverted and knife edge. No Patrick fix on this one.
_____________________________
AKA,, "The Spleen"
If you want to see my Super Power,,, pull my finger.
(in reply to turbo2000)
       Post #: 876
RE: BME 115 Any Fi... - 10/15/2007 6:15:42 PM
Hammbone
Status: offline
What kind of exhaust does Ron have?
Jim
(in reply to Steve)
       Post #: 877
RE: BME 115 Any Fi... - 10/15/2007 8:09:34 PM
Steve
Status: offline
He is running stock mufflers.
AKA,, "The Spleen"
(in reply to Hammbone)
       Post #: 878
RE: BME 115 Any Fi... - 10/15/2007 9:19:20 PM
SMALLFLY-
Status: offline
What's a stuffed reed block?
Big Fish in a Small Pond
(in reply to Steve)
       Post #: 879
RE: BME 115 Any Fi... - 10/15/2007 9:21:56 PM
RTK
Status: offline
Here is a pic
Click to see fullsize image.
Click for fullsize
(in reply to SMALLFLY-)
       Post #: 880
RE: BME 115 Any Fi... - 10/15/2007 9:38:13 PM
tonyc
Status: offline
Looks like two wood plugs are place in side the block to take up space. Reduce fuel builf up? The lower wood plug is larger than the upper one in the picture. Is there a science to this or how do you determine the correct size?
(in reply to RTK)
       Post #: 881
RE: BME 115 Any F... - 10/16/2007 4:49:53 AM
Steve
Status: offline
The plugs are the same size. They just need to be fuel proofed or you can make some out of fuel resistant materials. The plane flew another three flights again today with no hickups. It just ran, and ran strong.
AKA,, "The Spleen"
(in reply to tonyc)
       Post #: 882
RE: BME 115 Any F... - 10/17/2007 5:23:53 AM
jst
Status: offline
To the other testers of PATRICKP, (HAMMBONE is waiting for a rudder), any testing results to share with us?
(in reply to Steve)
       Post #: 883
RE: BME 115 Any F... - 10/17/2007 1:17:59 PM
Wings-RCU
Status: offline
Patrickp has graciously offered his kit to me, and I would love to test one out and report back here.
The problem for me is that the kit is for the older wga carb. Patrickp has also offered to loan me a carb for testing but I would need to move around the throttle & choke servos and of course buy a old carb and the kit if it all works out.
Tony, Steve, I used plastic pulgs in my read block and it really didn't make much difference.
Click for fullsize
(in reply to jst)
       Post #: 884
RE: BME 115 Any F... - 10/17/2007 2:15:25 PM
tonyc
Status: offline
Observation! When I look at post #880 by RTK and post #884 by Wings-RCU the blocks look like they are larger in Wings-RCU picture. If the block are there to reduce fuel pooling could a larger block reduce the pooling too much? Both of you are re-desiging the carb block to work in a different way. Could reducing the size a small amount on Wings-RCU block give him a better set up? Just a thought.
(in reply to Wings-RCU)
       Post #: 885
RE: BME 115 Any F... - 10/26/2007 6:44:52 PM
PATRICKP
Status: offline
So what happened to this thread? AKA as finding the fix for the 115 engine.
The testers have gotten lost in the clouds or in the triangle and do not have IFR to find a place to land.
Or they may have been captured by the enemy.
All owners are due the real fix and the right answers.
Let them know how the kit works and who should buy or supply the fix to the owners.
Mine works very well and yours can too.
(in reply to tonyc)
       Post #: 886
RE: BME 115 Any F... - 10/26/2007 7:21:32 PM
Rocky V.
Status: offline
Hey Patrick: just to clarify, will your fix work on the original carb with the tall reed block as well as the others ? I'm waiting patiently to see what the testers think and if it works out (and I sure hope it does), how the ordering process is going to be handled. If it works it will save me from getting tuned pipes/headers as Kris recommends. The pipes are fine, but we don't have noise restrictions currently so I'd rather run compact mufflers to save a little weight if possible.
Victim of Gravity...
(in reply to PATRICKP)
       Post #: 887
RE: BME 115 Any F... - 10/26/2007 7:51:03 PM
PATRICKP
Status: offline
As far as I can tell it won't matter what carb you are using I do have both kits for old vs new carb that came on the engines.
The engine ran poor/same with both carbs and the kit made the problem go away.
If you have the wga9a carb I do have a kit ready for that too.
It is not a carbkit.
It has nothing to do with the carbs at all.
Although having a tuned exhaust system will make more power overall.
The shorter the headers the more fussy things are to tune, for overall rpm ranges
short headers are for max rpm top end power.
The longer the header, they will make more low to mid range power. and are easier to tune.
With stock exhaust you have no header length. more pulses as explained by Kris.
So anyway you should be able to make run engine well, maybe not the very best but it should run.
(in reply to Rocky V.)
       Post #: 888
RE: BME 115 Any F... - 10/28/2007 4:24:22 PM
DMichael
Status: offline
I spent two days flying with PatrickP - his engine ran great all weekend. It is like night and day.
What is going on with the guys that have the kits to try out? I got to tell you, I am sympathetic to Hammbones situation with his rudder. Having said that- watching him sit on the sidelines waiting for a rudder has convinced me that I don't want an FMG kit, even if they are beautiful.
Hammbone- why don't you just stuff your engine into your buddies plane and try it out? Winter is coming......
Dave
Team ZDZ
www.rcshowcase.com
       Post #: 889
