RE: BME 115 Any Field Reports?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: BME 115 Any Field Reports?
Page: <<   < prev  32 33 34 35 36 [37] 38 39 40 41   next >   >>
Login
RE: BME 115 Any F... - 11/15/2007 1:00:11 AM
altavillan
Status: offline
Mines running so good I figured it was time to start telling whats under the hood.
And gave'er an appropriate name.
Click to see fullsize image.
Click for fullsize
Click for fullsize
_____________________________
I didn''t put the bullet in the fire and you quit talking about my mother! "Cosby, Shop Class, 1968 or so"
(in reply to Tired Old Man)
       Post #: 901
RE: BME 115 Any ... - 11/15/2007 1:38:20 AM
RTK
Status: offline
First time I ever had my name put on a plane, might be bad luck ............What's ANERS CRAMP??
(in reply to altavillan)
       Post #: 902
RE: BME 115 Any ... - 11/15/2007 2:14:39 AM
Tired Old Man
Status: offline
Oh schiest! Throw us all under the bus why don'tcha?
If you can''t fix it with a hammer, you have an electrical problem.
(in reply to RTK)
       Post #: 903
RE: BME 115 Any ... - 11/15/2007 2:19:10 AM
altavillan
Status: offline
Pat, Splain to Ralph what PITA means.
It was a team effort baby!
       Post #: 904
RE: BME 115 Any ... - 11/15/2007 1:22:46 PM
Tired Old Man
Status: offline
Pain.............. If he hasn't figurerd that one out by now it ain't gonna happen. I"ll be wanting to talk with you about graphics ordering, sizing, and costs the next time we get together.
       Post #: 905
RE: BME 115 Any ... - 11/15/2007 2:17:23 PM
altavillan
Status: offline
Bout time for you to do a RubyRed (pink) slippers search.
The graphics were a piece of cake to order, Bad Brad has been doing it long enough that he understands what you want. He has ready to go sets posted on his site. Easy to work up a set from there. http://www.badbradgraphics.com/index.html
       Post #: 906
RE: BME 115 Any ... - 11/15/2007 5:12:18 PM
Tired Old Man
Status: offline
Gawd you're gettin ornery
       Post #: 907
RE: BME 115 Any ... - 11/18/2007 12:06:12 AM
Hammbone
Status: offline
I know it's not December 25th, but it feels like Christmas here at my house today. Look what just arrived.
Click for fullsize
Click for fullsize
       Post #: 908
RE: BME 115 Any ... - 11/18/2007 12:08:43 AM
Hammbone
Status: offline
I'll get the new rudder installed ASAP, and I'll finally be able to give a report on the Patrick fix within a couple of days.
I still wonder what happened to the other guys trying out the Patrick fix. Where are their reports???
Jim
(in reply to Hammbone)
       Post #: 909
RE: BME 115 Any ... - 11/18/2007 2:46:44 PM
Rocky V.
Status: offline
That's an exellent question, how many did you send Patrick ?
Victim of Gravity...
       Post #: 910
RE: BME 115 Any ... - 11/19/2007 12:52:44 PM
PATRICKP
Status: offline
ONLY 2 KITS ARE OUT FOR TEST/REVIEW.
I will call the other today to see what is up.
(in reply to Rocky V.)
       Post #: 911
RE: BME 115 Any ... - 11/19/2007 11:44:15 PM
Hammbone
Status: offline
O.K., I tested the Patrick fix today. It was a definite improvement. My 115 used to sag horribly in Knife edge and when inverted. It doesn't do that any more. The engine still does not run good though. I'd say the Patrick fix has turned my horrible running 115 into just a bad running 115. It improved it, but not enough.
The engine still surges and hesitates at low and mid rpm's. The engine still seems like it might die. I made several adjustments to the needles today. I know my low end was as lean as it could go because I had it a little too lean and it almost quit on take off again (that's what damaged my rudder before) once. I richened it a little from that point and it didn't hesitate on take off any more after that. I had the high end anywhere from a little rich to a little lean and everywhere in between. Nothing worked. I was making very small (blade width) adjustments. There is just no way I can trust this engine. I didn't have any dead sticks today, but it always seemed like it might die.
I think that I have 2 things working against me:
1. I am using the stock exhaust
2. I fly at high altitude
I just don't think there is anything I can do to overcome these obstacles. Flying at high altitude makes a rich mid range even richer. I do not like the complexity and the added weight of cans or pipes.
If someone is flying at a lower altitude with cans or pipes and your having some rich mid range problems, I think the Patrick fix could solve your problems. If the other guy testing the Patrick fix would report his findings, we might hear just this.
For me though, I am through messing with the BME 115. I've been messing with it all year. Nothing works. It will go up for sale and I will put a different engine on the plane.
Jim
(in reply to PATRICKP)
       Post #: 912
RE: BME 115 Any ... - 11/20/2007 4:34:39 AM
CH3CH2OH
Status: offline
Hammbone or RTK, have you tried the second carb with mod. If so was it a fix and did it tune more like other engines?
       Post #: 913
RE: BME 115 Any ... - 11/20/2007 12:41:12 PM
PATRICKP
Status: offline
All,
I Talked with the other testor of kit last night.
They have tested and the testor will post the results also.
It was much better than Hams results.
The kit did take out the problem of rolling to edge/inverted RPMs dropping for Ham and the others.
The kit along with a better carb also may be the best way to fix higher elevation problems.
These current factory carbs we have are all hard to tune ROUND vs TAPER seating.
Kit and also the new better carb( 3 needles ) may be needed for high elevations.
Regards,
Patrick
(in reply to CH3CH2OH)
