Tired Old Man
Joined: 2/25/2002 From: Central, CA, USA Status: offline
Pontiac40 You'll need 3-1/2" to 3-3/4" bolts to make the lengths work if you use a wood standoff. My 4" bolts are about 1/2" too long, even allowing for 1/4" of excess to pass through the nut and washer. Comp Arf U.K has some photos on how to make a removable tank tray. The stock version pretty near prohibits removing thr rudder servos if you use the stock rudder tray. If you can come up with some 6 to 9 ounce carbon fiber and some good laminating epoxy I came up with a neat little bracket for mounting switches, Matchboxes and stuff. No screws going through the fuselage or internal parts. I imagine it could be done with fiberglass mat as well. Kraczy, That problem you are having seems pretty common for Falkon at the moment. You may want to consider getting a CH and retiming the engine to use it. Keith can give you the wiring color codes to cross over from the Falkon sensor to the CH. I have them too if you need them. The sensor you have can remain in place, but the wiring has to cahnge.
< Message edited by Silversurfer -- 4/8/2007 5:54:30 AM >
_____________________________
If you can''''t fix it with a hammer, you have an electrical problem.
