*Lightning Holes In Engine Box Area*
Tower Hobbies
Logged in as Guest
  Printable Version
52% Edge 540 153.5"WS
Seller:  Badge
Details:   $1,500.00   |  11/10/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> *Lightning Holes In Engine Box Area*
Page: [1]
Login
*Lightning Holes In Engine Box Area* - 2/28/2007 10:27:31 PM
Zippi
Status: offline
I have a Wild Hare Extra 300LX and there are lightning holes in the fire wall and engine box area. I normally cover these holes but on this plane I'm going to leave one open so I can access the bolts for the landing gear. I'm just curious as to how much air really passes through the cowl and into the fuse through these holes. Do you leave your holes open or cover them up?
Click to see fullsize image.
Click for fullsize
Click for fullsize
_____________________________
"It Ain''t Lookin Good"
http://zippi.50webs.com/index.htm
       Post #: 1
RE: *Lightning Holes In Engine Box Area* - 2/28/2007 10:44:55 PM
Jake Ruddy
Status: offline
You should leave them open. In most cases any air compressed in there actually helps strengthen the fuse (from what I was told)
Not sure if that is 100% accurate... but that's what I was told
(in reply to Zippi)
       Post #: 2
RE: *Lightning Holes In Engine Box Area* - 3/1/2007 12:34:23 AM
Tired Old Man
Status: offline
Figure that enough air can pass though the lower openings to cool cannisters considerably. Since I don't use cannisters I always close off the lower opening into the fuselage via a deflection ramp but leave the others alone. The reason I close mine off is to better direct the air used for cooling. I prefer that the outflow assits the inflow, so diverting out the bottom of the cowl works to my advantage.
If you can''t fix it with a hammer, you have an electrical problem.
(in reply to Jake Ruddy)
       Post #: 3
RE: *Lightning Holes In Engine Box Area* - 3/1/2007 8:41:23 AM
marc 540
Status: offline
Strengthen the fuse?? Now thats funny!!
I know on the QQ Yaks the opening into the fuse is closed but the holes around the engine box are open. In other words, air can circulate around and in the engine box but not into the fuse.
Marc 540
quote:
ORIGINAL: sinergy
       Post #: 4
RE: *Lightning Holes In Engine Box Area* - 3/1/2007 12:33:04 PM
Zippi
Status: offline
Thanks for the input guys. I guess I'll cover the opening to the fuse with some Ultracote so if I need to get to the bolts for the landing gear I can just cut the Ultracote out.
(in reply to marc 540)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.359RCU5
