RE: wood props
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Pylon Universe - RC Pylon Racing >> QM-40 Racing >> RE: wood props Page: <<   < prev  1 [2] 3 4 5 6 7   next >   >>
Login
RE: wood props - 3/6/2007 2:39:22 AM
Bill Vargas
Status: offline
>>>Also, the 9x8's have a 1/2" thick hub.<<<
yea, its gonna be a tight fit with the small spinner but it can be done.
BV
_____________________________
If it ain't leaking oil, then something's wrong,,, USMC, RETIRED!
(in reply to daven)
       Post #: 26
RE: wood props - 3/7/2007 2:19:33 AM
Yo! Team Green
Status: offline
Hey Guys, Great discussion. Could one of you describe for me the "soak it in CA" step? Are you literally dipping the prop in thin CA or ??? And.. when sanding, are you trying to create an airfoil shape on the back or is it a flat shape at the proper pitch angle?
>T
Had a bad year? My newest plane is a Bird of Pray.
(in reply to daven)
       Post #: 27
RE: wood props - 3/7/2007 3:14:27 AM
iamtom
Status: offline
The back side is in fact flat. Soaking in C/A is exactly right. Take a piece of 1"ID PVC tubing about 3 1/2 " long and glue a plate on one end. Fill the tube with thin C/A and dip one blade at a time for 30 to 60 seconds. Wipe clean with a paper towel and let cure. when done sand with 400 and do again but for just an instant. Again wipe clean and sand with 400 again then 600 and Mothers, If it dosn't look well coated repeat until you are sure it is coated. You also can use this technique to balance by the additive method. Add a coating to the light side rather than sand the heavy side. This C/A treatment will protect the wood and add great stiffness.
Tom
(in reply to Yo! Team Green)
       Post #: 28
RE: wood props - 3/9/2007 5:08:22 AM
daven
Status: online
I stopped by the hobby store and bought out their 8x7 zinger props, I think they had 6 of them. The hub is thinner, can't wait to get started.
What length do you leave the props at?
I was thinking keeping the lighter pitchs at 7 5/8", medium at 7 1/2", and lighter pitches at 7 3/8"
This is for the LS motor.
Dave Norman
klasskote.com
supertrc.com
(in reply to iamtom)
       Post #: 29
RE: wood props - 3/9/2007 1:44:34 PM
iamtom
Status: offline
I think Craig cut his Zingers to 7 3/8" long. Then tune for the RPM you desire.
Tom
(in reply to daven)
       Post #: 30
RE: wood props - 3/10/2007 1:14:12 AM
airbornrc
Status: online
Is there a chance some one could post the article mentioned early in this thread?
Mark Anderson
(in reply to daven)
       Post #: 31
RE: wood props - 3/10/2007 2:08:35 AM
proptop
Status: offline
If you're talking about the May '99 M A article...I found it in the AMA site archives. It took some work, but I finally dug enough to find it. You have to put in your AMA # and register, but you can access just about any article in the M A back issues that you want.
It's bad luck to be superstitious...
Revver Bro #77
(in reply to airbornrc)
       Post #: 32
RE: wood props - 3/10/2007 1:52:37 PM
BUDMAN27
Status: offline
Looks as though someone has turn the clock backwards. Guys going crazy carving wood props again. Next they will be bring back F-1
(in reply to proptop)
       Post #: 33
RE: wood props - 3/10/2007 2:52:23 PM
Ed Smith
Status: offline
Well I hope so. I still have one ready to go.
Ed S
(in reply to BUDMAN27)
       Post #: 34
RE: wood props - 3/10/2007 8:39:08 PM
proptop
Status: offline
I thought we were supposed to turn the clocks ahead?!
Maybe I'm just ahead of my time?
Revver Bro #77
(in reply to Ed Smith)
       Post #: 35
RE: wood props - 3/11/2007 12:09:06 AM
proptop
Status: offline
I bought a 6 pack of Zinger 8 X 7's...
Next step to get 'er done will be to find a pitch guage?
I see one mentioned on Darrol Cady's site, but there's no price...they might be hard to get? Prather's site is being modified, or under re-construction?
What about the Edmunds one?
< Message edited by proptop -- 3/11/2007 12:10:31 AM >
Revver Bro #77
       Post #: 36
RE: wood props - 3/11/2007 1:48:01 AM
Tony Pacini
Status: offline
quote:
ORIGINAL: proptop
Prather is closing their doors and you probably won't be able to get any of their gauges. I got an Edmunds pitch gauge from Darrol and it is nice (I prefer it over the Prather).
       Post #: 37
RE: wood props - 3/11/2007 1:54:25 AM
proptop
Status: offline
Thanks Tony...
I sent Darrol an e-mail just a little while ago, and asked about a few other things as well.
I think I will get the template and some blanks (they look like Rev-Up's?) too.
Revver Bro #77
(in reply to Tony Pacini)
       Post #: 38
RE: wood props - 3/11/2007 3:10:54 PM
daven
Status: online
Proptop,
I checked that May 99' article, which looks good, but I don't think its the one Tom meant.
The May 99' was authored by Duane Gall (RCU's DHG), I'm still trying to locate the Vern Smith Article.
Dave Norman
klasskote.com
supertrc.com
(in reply to daven)
       Post #: 39
RE: wood props - 3/11/2007 3:28:17 PM
daven
Status: online
No luck finding it on the AMA website.
If anyone has access I would love to see it.
Dave Norman
klasskote.com
supertrc.com
(in reply to daven)
       Post #: 40
RE: wood props - 3/11/2007 5:59:28 PM
iamtom
Status: offline
I am pretty sure Grunk said it was in the NMPRA newsletter from that time. I will make sure. This was when Vern was President.
Tom
(in reply to daven)
       Post #: 41
RE: wood props - 3/11/2007 8:25:58 PM
