RE: The official UNOFFICIAL thread of Tamiya Frog - LB stikes again..
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Electric Off-Road Trucks, Buggies, Truggies and more >> RE: The official UNOFFICIAL thread of Tamiya Frog - LB stikes again..
Page: <<   < prev  2 3 [4] 5 6 7 8 9 10 11   next >   >>
Login
RE: The official UNOFFICIAL thread of Tamiya Frog - L... - 3/1/2007 7:42:33 PM
CPR KART
Status: offline
quote:
ORIGINAL: Lunchboxer
Then you should start a thread about it and see if you can get enough traction...
I already tried It only made it to 12 posts.
_____________________________
Formally known as Checkpointracer
(in reply to Lunchboxer)
       Post #: 76
RE: The official UNOFFICIAL thread of Tamiya Frog - L... - 3/1/2007 7:44:08 PM
Lunchboxer
Status: offline
I guess not enough people have the Sand Viper.. Maybe you need to get a more popular car to if you want to join all the discussion.. (not that should be important.. you should just have fun w/ whatever you have!)
Anyway, to keep in top, here's an old ad for The Frog!!
Click to see fullsize image.
Click for fullsize
LB | WW2 | TLT | TB02 | DF03 | TEgg | TC4FT | F103GT | TXT | Hornet | M03M | Frog | Scalpel | Leo 2A6 | Aeromax | WW1 | Clod
(in reply to CPR KART)
       Post #: 77
RE: The official UNOFFICIAL thread of Tamiya Frog - L... - 3/1/2007 7:53:47 PM
coleholley
Status: offline
4 Pages already and the car hasn't even arrived yet. LOL. I can tell you are really wanting the FROG to show up like right now. I can't believe you didn't overnight it even though you do get free regular shipping.
Pede | BlizzardX2 | Rustler | T-Maxx | Blade CX2 | XX-CR | B3 | Evader | RC18MT | Typhoon 2 | Super Cub | Micro Cessna 210
       Post #: 78
RE: The official UNOFFICIAL thread of Tamiya Frog - L... - 3/1/2007 7:56:31 PM
Lunchboxer
Status: offline
Me?! Nah.. I am all about saving $$$.. I still got kits NIB at my place that's not built-up yet, so... hee hee.. it is all about patience and buy things when the right coupon shows up.. hee hee..
Should be here early next week.. and I will spend a few days building it.. (I am sure one can finish it in one day, but what's the fun of that?! Ha!)
(in reply to coleholley)
       Post #: 79
RE: The official UNOFFICIAL thread of Tamiya Frog - ... - 3/1/2007 8:19:18 PM
BuzzBomber
Status: offline
I had an original Frog which I got for Christmas in, I think, 1985. My first hobby-grade r/c, and it stuck around till about 1990, serving as a buggy, with a blackfoot body on homemade mounts, heck I even put foam tires on it and ran it on-road with a monte carlo body. Last April, I bought one of the re-issue Frogs, and I've probably accumulated as much runtime on it already as I ever did on the old one. It's pretty much stock, with the exception of a Trinity CO27 Pro, ballbearings all the way around, and the CVD setup from Tamiya.
The body is torn and looks like hell, the skid plate is bashed in, and the transmission is all ground up on the bottom from too many jumps onto asphalt. The spaceframe chassis has a few white areas(fatigue marks), too. Not long after I swapped out the silver can for the Trinity motor, I started losing the dogbones a lot, especially on jumps, and wound up with quite a bit of play, to the point where I had to shim the outdrives with nylon washers. Over time, the trailing arms developed a lot of play, too, where they mount to the transmission cases. With everything tightened up all the way, I can move the arms in/out about 1/8" per side. The stock dogbones won't stay in with this kind of play. When I added the CVDs, I discovered that they are just a *bit* short, so that the inner ends would pop out of the drive cups when the suspension's fully extended, ie. in the air. I had to fit a 1/8" piece of fuel tubing on the shock shaft inside the shock body to shorten up the travel so this wouldn't happen. Also, after a few cartwheels, I started having problems with the front stub axles coming out of the uprights(the steel axles are press fit into the pot metal uprights)--jbweld seems to have that cured. Also, you may want to fabricate some kind of battery guard--I made one out of a piece of lexan as long as a stick pack and about 3" wide, heat bent into an "l" shape to cover the front and bottom edges of the exposed pack. Otherwise, your packs will take a beating.
Despite all this, I still haven't blown out the differential yet! I may not be the best example of what to expect to break, because I actually beat on this car harder than my modern ones, like setting up jumps to clear a 12' gap in a parking lot, jumping off a 3' cliff, etc. Anyway, have fun with your new Frog, it's hard not to!
< Message edited by BuzzBomber -- 3/1/2007 8:21:41 PM >
Matt Smith
If you''re not having fun, you''re missing the point.
       Post #: 80
RE: The official UNOFFICIAL thread of Tamiya Frog - ... - 3/1/2007 8:31:37 PM
Lunchboxer
Status: offline
Man, that's Frog abuse there!! NICE!! Glad to see people actually using it the way it is meant t obe used!! I doubt I will be that hard on my Frog.. (Heck, I barely run any of my cars.. I am more into building them.. ha!) But yeah, I will most likely get the CVD anyway..
Post some pics of your beat up Frog when you got a chance!!
(in reply to BuzzBomber)
       Post #: 81
RE: The official UNOFFICIAL thread of Tamiya Frog - ... - 3/1/2007 8:41:30 PM
rc monkey
Status: offline
Typical LB, 4 pages and still no car I would love a vintage tamiya but can't justify it - I already have a buggy etc Oh to have a job
Outrunner Powered Xray XB8TQ - Custom Sand Rail - Team Losi Micro Baja - Custom Crawler
       Post #: 82
RE: The official UNOFFICIAL thread of Tamiya Frog - ... - 3/1/2007 8:45:45 PM
Lunchboxer
Status: offline
rc monkey, are you a student now? or?!
yes, it helps to have a job, hee hee...
yeah, 4 pages and still no cars.. LOL!! at least I didn't start buying hop-ups before buying the car on this one, ha ha ha ha ha!!
(in reply to rc monkey)
       Post #: 83
RE: The official UNOFFICIAL thread of Tamiya Frog - ... - 3/1/2007 8:52:12 PM
rc monkey
Status: offline
14 and not alot of money
       Post #: 84
RE: The official UNOFFICIAL thread of Tamiya Frog - ... - 3/1/2007 8:54:40 PM
Lunchboxer
Status: offline
MM7700kv, not bad for a 14 yr old...
       Post #: 85
RE: The official UNOFFICIAL thread of Tamiya Frog - ... - 3/1/2007 9:03:57 PM
rc monkey
Status: offline
Well that blew literally all my savings
       Post #: 86
RE: The official UNOFFICIAL thread of Tamiya Frog - ... - 3/1/2007 9:09:43 PM
CPR KART
Status: offline
Ugh I know how you feel. I save up for something for a long time and blow it an about 3 minutes on an order. If I wasn't 12 I'd probly have a tamiya lunchbox, TT-01, b4, tc4, xxx-t brushless, and a mamba max 5700 to top it off.
quote:
ORIGINAL: rc monkey
       Post #: 87
RE: The official UNOFFICIAL thread of Tamiya Frog - ... - 3/1/2007 9:12:41 PM
CPR KART
Status: offline
Hey LB why do you call it the official UNOFFICIAL?
       Post #: 88
RE: The official UNOFFICIAL thread of Tamiya Frog - ... - 3/1/2007 9:16:22 PM
Lunchboxer
Status: offline
Because I see everyone wants to claim that their thread is the "official" thread.. I just thought that's pretty funny.. (what makes one more official than the others?! ha!) So I just says, this is the official "unofficial" thread.. LOL!!
quote:
ORIGINAL: p2k2racer
       Post #: 89
RE: The official UNOFFICIAL thread of Tamiya Frog - ... - 3/1/2007 9:19:21 PM
CPR KART
Status: offline
Am still confused why you put UNOFFICIAL in it.
       Post #: 90
