jessemxt
HI, USA Status: offline
quote:
ORIGINAL: mxr Yep , it doesn't look too good,look's like a piece af metal got caught between the exhaust port and the piston,i would open the engine and check that the bearings didn't blow out . Have you ever tried to lock the piston by the exhaust port in order to unscrew the flywheel ? I have seen that being done before and it also leaves those marks on the piston . What starter box are you getting ? I guess that you also have the RTR version ? how much fuel have you been through with the engine ? Mine has seen about 1/2 a gallon or even less and the piston has almost no pinch at all any more . I just got the engine used for a good price.It is a O.S 18tz and it is supposed to have less than a gallon on it. I have no idea of what the previous owner did to it. I am getting the Ofna mini starter box.
_____________________________
cna yuo rdea tish yuo aer a bgi nred leki me =) Nomadio React, ACE 1313,
