hongnor
Joined: 5/6/2008 From: poole, UNITED KINGDOM Status: offline
quote:
ORIGINAL: mxr quote:
ORIGINAL: hongnor ive had my crt.5 going with the sirio 15 motor ,, its fast , i cant control it on the straights , still keeps up with the big boyz thou .. .. just trying to sort my shocks out , they,re now leaking , gonna fit crt (normal crt )front shocks on the rear .. and what wheels/tyres do you run ... Hi When you got that engine on the 5 ,did you gear up the bell ?If yes how many teeth bell did you put on the CRT5 ? I oredered a 15 Teeth bell to go along with my 18TZ but i am a little scared it wont be enough ... hi ive geared it up to a 15t , along with the 2.2" wheels/tyres ... ive also fitted the light weight spur gear ,which is meant to increase take off , ive only tried it on tarmac seems to pull ok ....i think i could go up another tooth on the cb ,but ill see tomorrow at the track.... i recon a 15t bell may not be enough , maybe a 16/17t with 2.2"wheels / tyres ...may be better ..
