mxr
Joined: 4/7/2007 From: Jyväskylä, FINLAND Status: offline
quote:
ORIGINAL: hongnor ive now changed the sirio 15 to a os 18tz , as the sirio had air leak isues , but only found out what it was when the motor was out ,( leak on the side of the carb .. now sorted ..done 5 tanks on the os and it wheelies with a 17t .. and a 1/2 a turn richer than base settings .. I have allready one OS18TZ in my RC10GT and i had to back up a 1/4 turn on the HSN than the base setting as it was running too lean ,but that thing even with a very high gearing wheelies at the end of our straight on our track and if i insist a little more it goes airborn,with that engine my RC10GT is even faster on the straight than most of the 1/8 buggys out there.but when comes time to turn or brake you have to pray to be able to make it . With what you tell me i guess that a 15 bell will not be enough to calm the beast on the track as my goal is to be able to keep up with the 1/8 buggys and still be able to outrun them in the turns i have made a bet with a friend that i could be in the top 5 on our next race in one month racing in the 1/8 class ...
