RE: Official Thread for X1 CRT .5 Truggy
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Truggy >> RE: Official Thread for X1 CRT .5 Truggy
Page: <<   < prev  4 5 [6] 7 8 9 10 11 12 13   next >   >>
Login
RE: Official Thread for X1 CRT .5 Truggy - 6/22/2007 5:11:51 PM
low_blow_joe
Status: offline
hey guys... anyone out there have a leaking problem with the stock crt.5 fuel tank? i also notice that the radio box cover tends to pop out rather easily after a crash...
(in reply to rcmxsports)
       Post #: 126
RE: Official Thread for X1 CRT .5 Truggy - 6/23/2007 3:50:42 AM
rcnitrofreek
Status: offline
here is my new crt.5 caint wait to test it out looks good and feels good so we will see,it has the expensive jr servos in it and they work great!!!!!
http://i19.tinypic.com/5z2pqf6.jpg
(in reply to low_blow_joe)
       Post #: 127
RE: Official Thread for X1 CRT .5 Truggy - 6/24/2007 4:28:56 PM
low_blow_joe
Status: offline
hey anybody knows what after market tyres that can fit the crt .5. will the 2.2 rear buggy tyres fit into the stock crt.5 rims? or must i get the 1/10 2.2 truck tyres? im looking at those pro-line tyres they got lots of varieties
(in reply to rcnitrofreek)
       Post #: 128
RE: Official Thread for X1 CRT .5 Truggy - 6/24/2007 9:14:09 PM
luisev
Status: offline
I thought the CRT.5 already came with Pro-Line Bow Ties... and yes, I believe either Buggy or Truck 2.2 tires will fit.
_____________________________
Go Tech, JConcepts, Upgrade RC Dealer
www.rcloverz.com
       Post #: 129
RE: Official Thread for X1 CRT .5 Truggy - 6/26/2007 7:22:23 AM
cnguyen831
Status: offline
I have the kit with the engine. DO I need a metal o ring with the included glow plug? I am using hitec servos and the plastic gear piece that fits over the servo doesn't fit well. Any tips?
(in reply to luisev)
       Post #: 130
RE: Official Thread for X1 CRT .5 Truggy - 6/26/2007 8:21:11 PM
trackman
Status: offline
not sure what plug you have but turbo plugs dont use a washer. i had the same problem with mine, the
inserts dont fit. i used the red arms that came with the servos, i think they will hold up fine.
the .5 is designed to use 2.2 buggy tires, any should fit. im using proline and panthers.
(in reply to cnguyen831)
       Post #: 131
RE: Official Thread for X1 CRT .5 Truggy - 6/28/2007 12:17:31 AM
RedneckCubano
Status: offline
I'm thinking of getting a CRT .5. should I go with the picco .12 or something else? any suggestions? how bout an O.S. 18?
(in reply to trackman)
       Post #: 132
RE: Official Thread for X1 CRT .5 Truggy - 7/1/2007 10:25:35 AM
luisev
Status: offline
quote:
ORIGINAL: Jerseyboy
quote:
ORIGINAL: lazyboy12300
Is that a SH .12?
Yes thats a SH12 turbo. I am amazed at the perfomance. As you can see it is freakin awesome. The engine is not yet runin.
This is the handbuilt SH 12. The engine idles constant and temps are very cool. I can play for 10min before refuelling.
The engine is also very cheap compared to the other so called high end mills.
Is this the one you have?
http://www.hobbypeople.net/gallery/147005.asp
www.rcloverz.com
(in reply to Jerseyboy)
       Post #: 133
RE: Official Thread for X1 CRT .5 Truggy - 7/2/2007 6:51:30 AM
Jerseyboy
Status: offline
Yes, mins the casing is black. Its the same engine just a slightly newer version.
       Post #: 134
RE: Official Thread for X1 CRT .5 Truggy - 7/2/2007 5:02:17 PM
luisev
Status: offline
Excellent thanks... my CRT.5 is on it's way, so I'm off to purchase the SH12 now. For the price, the SH seems like you can't beat it.
www.rcloverz.com
       Post #: 135
RE: Official Thread for X1 CRT .5 Truggy - 7/4/2007 8:30:47 PM
luisev
Status: offline
quote:
ORIGINAL: Jerseyboy
The next step was the part I was looking forward to. The servo mounting.
I tried to follow all the CRT threads on servo mounting and found that everyone uses either one full sized and one mini servo.
Well I have 2 digital HT servos that is too weak to use in my 1/8th scale and I was planning to make it work in my CRT .5 .
I followed the instruction I found on Truggyraces and I must say that this is probably the easiest mod for full-sized servos.
Can you send me a link to the mod? I can' t see to locate it on truggyracers
quote:
ORIGINAL: Jerseyboy
I also noticed that the chassis has quite bit of flex in the centre. I also read about some guys putting in extra braces, I also compared the flex with the servo tray mounted. It has similar flex. I think this might be a problem later. I’ll look at resolving that.
So far so good. Have not started but I will keep you updated.
Hope the pics are clear.
Any further insight into solving the flexing issue? BTW my SH12 is on it's way...
< Message edited by luisev -- 7/4/2007 8:31:15 PM >
www.rcloverz.com
       Post #: 136
RE: Official Thread for X1 CRT .5 Truggy - 7/5/2007 1:48:24 AM
Baja5BLST
Status: offline
Just buy the BCE chassis. Boom, no more flex.
Baja 5B, Mugen MST-1, LST
48.62% of statistics are made up on the spot
       Post #: 137
RE: Official Thread for X1 CRT .5 Truggy - 7/5/2007 3:54:41 AM
luisev
Status: offline
Have a link to where it can be purchased? I thought they weren't available yet...
www.rcloverz.com
(in reply to Baja5BLST)
       Post #: 138
RE: Official Thread for X1 CRT .5 Truggy - 7/5/2007 4:23:42 AM
Baja5BLST
Status: offline
truggyracersdotcom. Check the CRT forum, and contact the maker personally for your answer
       Post #: 139
RE: Official Thread for X1 CRT .5 Truggy - 7/9/2007 4:28:24 AM
BRUSHLESS BASHER
Status: offline
this is going to be my next rc, and I want to use the .18 tz-tx from my revo, my first question is: does it come with a bump starter? and if not can I use a roto or pull starter? my second question is: will a revo pipe fit on it?, I have a trinity pipe, but if I have to I can use a different header, like the 4-tec's:
Click to see fullsize image.
Click for fullsize
Click for fullsize
       Post #: 140
RE: Official Thread for X1 CRT .5 Truggy - 7/9/2007 8:13:11 AM
cnguyen831
Status: offline
I have a 5V hump pack and a Spektrum RX. How did you fit both into the tray with the top closed? Where did you put the wiring?
       Post #: 141
RE: Official Thread for X1 CRT .5 Truggy - 7/9/2007 5:47:35 PM
supertib
Status: online
