Texas_Flyer -> RE: New Somenized (TM) 69", Yak-54 (9/28/2008 5:33:08 AM)
Finally completed my Yak and maidened it today. :-) I'm using a Saito 125, 16x6 prop, Cool Power 30%, Futaba 2.4 Rx, and various digital servos. I don't have a final weight, but preliminary weighings were putting it about 8 lb - excellent for the size. While the 6 pitch prop doesn't fly very fast, it has lots of pull - takeoffs are in about 10'. The most amazing thing is that I couldn't get it to stall in slow flight. I cut power and gave it some elevator and it just seemed to float in the air - and there was no wind to hold it up! I yanked the elevator at different times and couldn't get that to stall either. In very little time, I gained a lot of confidence in this plane. I'm still slowly moving the CG back and am almost where I want it (roughly neutral). This has resulted in nearly zero coupling in KE. The only issues I had were that the canopy rattles in the front (some foam saddle tape should do the trick) and the covering really loosened in the sun (the heat gun should solve that). Overall, I've very pleased with the results, though the assembly took much more time than I anticipated. Thanks to all of you who posted in this thread to help those coming behind you. Alan
