Brenner
MI, USA Status: offline
I agree, customer service at QQ Aircraft Co. is solid, and that's good. The other thing they have going is "Branding". Everybody knows Quique's accomplishments, and that engenders a certain amount of trust with customers who are looking for planes that are designed & built to fly well. Ten years ago, if you wanted a good flying aircraft, you had either had to design and build it yourself, or buy a basic kit (foam cores & glass fuse..) from a "name" flyer, and build that. This was because planes & kits from any other source were designed and built by people who didn't always understand what was needed to make a plane fly well. Things like Stab Vertical Location, Rudder Centroid Vertical Location. Wing & Stab Incidence, Engine Right & Down Thrust. Wing Dihedral, CG, etc... Usually what you'd end up with was a plane that was too heavy, had huge rudder to aileron coupling, huge rudder to elevator coupling, and was speed sensitive so it wouldn't lock on to a line. Oh, and if you tried to put a motor with enough power into it it would be nose heavy, and would vibrate too much. Hopefully, thanks to QQ Aircraft Co., those days are over. However, I am a little distressed to see some of these "wrong / bad part" issues. This kind of thing suggests a certain lack of attention to detail. I hope that the problems are limited, and that they can all be corrected soon. Brenner ...
