RE: 69" QQ Yak-54
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Quique's Aircraft Support >> RE: 69" QQ Yak-54
Page: <<   < prev  5 6 7 [8] 9 10 11 12 13 14   next >   >>
Login
RE: 69" QQ Yak-54 - 10/2/2007 3:00:25 PM
asmatt2
Status: offline
Reza,
If I am running a 4.8V 2500mah battery, what servos would you recommend?
(in reply to cje0114)
       Post #: 176
RE: 69" QQ Yak-54 - 10/4/2007 5:46:36 PM
asmatt2
Status: offline
I went ahead and got the 5645's on all surfaces and a 5245 on the throttle. What fuel is everyone running through their YS 110?
(in reply to asmatt2)
       Post #: 177
RE: 69" QQ Yak-54 - 10/8/2007 4:07:57 AM
ben beyer
Status: offline
I'm using the Curtis Youngblood 30% Heli fuel.
_____________________________
Team DOD Member
www.downonthedeck.com
       Post #: 178
RE: 69" QQ Yak-54 - 10/22/2007 6:31:42 AM
UMD Pilot
Status: offline
Hello Everyone,
I am just joining this forum so I figure I will introduce myself. I just recently got back into R/C after a slight break due to time crunches with school. I was ALWAYS Quique Aircraft's BIGGEST advocate. I was in love with the planes and am a complete Yak-oholic. However, I never had the money to afford one of the larger Yak's. Now, I think I will have the resources to afford and properly equip this plane. It's the perfect size and is made by the perfect company.
There has been lots of debate about engines so far on the forum, so I wanted to see if i have a general idea of everyone's conclusions.
Saito 125 Four-stroke/O.S. 120 Four-stroke/YS 110 Four-stroke/O.S. 120 AX Two-stroke
Are these the main possibilities that everyone has liked?
Also, if these are the engines of choice, as far as the four-strokes are concerned which one is the most user-friendly? I only ask because I have heard negative things about YS engines and the constant tweaking they demand.
Thank you all for the help,
Matt
(in reply to ben beyer)
       Post #: 179
RE: 69" QQ Yak-54 - 10/27/2007 12:55:04 AM
kochj
Status: offline
I just wanted to post my findings with my OS 1.20AX 2-stroke on a MACS tuned pipe/header comb..
It will spin the 17x6 with stock muffler around 9200 RPM's.
I was using Wildcat/YS Performace 20%nitro 2or 4 stroke fuel.
tuned pipe w/a 17x6 APC prop 10000-10500 RPMS
That is a 1000+ RPM increase folks!!!
I am sure no one here is going to go for Scale show apperance?????
put that pipe on it and haul bones!!...
That will save you that 30% heli fuel and you engine will last longer....
Justin
Click to see fullsize image.
Click for fullsize
Winning isn''t everything, it''s all there is.
(in reply to UMD Pilot)
       Post #: 180
RE: 69" QQ Yak-54 - 10/27/2007 12:58:14 AM
cje0114
Status: offline
Hey Reza,
Is there any updates on the correct landing gear for this plane?
Chris
(in reply to kochj)
       Post #: 181
RE: 69" QQ Yak-54 - 10/27/2007 2:16:03 AM
Brenner
Status: offline
Yeah!
I'm interesting in learning about landing gear updates too, and if there is no update, I'd be interested to know if there's a third party landing gear available that will fit the 69" Yak. Preferably something made out of carbon fibre to keep the weight down.
       Post #: 182
RE: 69" QQ Yak-54 - 10/27/2007 2:44:05 AM
ben beyer
Status: offline
I got some CF gear from Graphtech. I haven't weighed them, but they do feel lighter than the stock gear.
Team DOD Member
(in reply to Brenner)
       Post #: 183
RE: 69" QQ Yak-54 - 10/27/2007 3:08:48 AM
Brenner
Status: offline
Which gear did you get?
       Post #: 184
RE: 69" QQ Yak-54 - 10/27/2007 3:22:34 AM
ben beyer
Status: offline
I got the one for the 73". You just need to tell them to sand it down to 1".
Team DOD Member
       Post #: 185
RE: 69" QQ Yak-54 - 10/27/2007 3:54:38 AM
Brenner
Status: offline
You mean this one?
#220 QuiQue 72" Yak 54 Version 4D
3-1/2" Base / 7-1/4" Total Height / 13-1/4" Spread / 1-1/4" to 7/8"
This gear is 1" Taller than stock and can be cut down if needed.
And did you mean ask them to cut off the extra 1"?
       Post #: 186
RE: 69" QQ Yak-54 - 10/27/2007 4:02:08 AM
ben beyer
Status: offline
That's the one. The top is 1.25" and that won't fit in the slot. That's what you need to have sanded down. As far as the height, I'm just letting mine sit a little higher. You could cut it down if you wanted to. I drilled my axle hole in the middle of where it would go and it sits about 1/4-1/2" higher.
Team DOD Member
       Post #: 187
RE: 69" QQ Yak-54 - 10/27/2007 4:35:52 AM
marlin847
Status: offline
Hey Reza have you heard when they are sending out the correct landing gear for this plane? Marlin
       Post #: 188
RE: 69" QQ Yak-54 - 10/27/2007 5:52:49 PM
Brenner
Status: offline
Good point!
I'd much rather have the stock gear, painted in the right color, without it being all cut up.
(in reply to marlin847)
       Post #: 189
RE: 69" QQ Yak-54 - 10/27/2007 11:13:20 PM
Rezagh
Status: offline
Hi Guys,
I will check on the landing gear status and let you know.
Thank you,
Reza
Quique's Aircraft Company
