Brenner -> RE: 69" QQ Yak-54 (11/6/2007 4:06:53 AM)
Now that I think about it, you could probably get by with an A123 10s1p pack and end up saving weight. This would give you 2300 mah as compared to your current 4200 mah pack, but if you're getting 8.5 minutes with only 2100 mah now, 2300 mah should get you 9 to 10 minutes easy. Combine this pack with a switching mode BEC, and MotoCalc tells me that the resulting plane is going to weight about 8.5 lbs, the same as the equivalent glow version. Actually, MotoCalc is telling me that a 10s1p A123 pack is going to draw quite a bit more current than a 10s2p A123 pack which lowers the pack voltage, so the optimim configuration is going to be closer to a 12s1p pack. The resulting specs would be as follows: Full Throttle Motor Current : 69 Amps - 30C All-up Weight: 9.1 lbs Power: 1817 Watts - 200 W/lb Static Thrust : 16 lbs Static rpm : 6616 Prop : 18X10 Wing Loading : 22 oz/sq.ft This would be a sweet setup. You'd fly for ten minutes, and then charge for fifteen minutes, without having to remove the battery pack from the plane, and I've heard that A123's can be drained repeatably without damaging the cells, so you could fly until the ESC blips the motor, and then land. All in all a very efficient way to fly. Right now on Ebay you can pick up a 10 cell A123 Dewalt power pack for about $10 a cell, and loose cells cost about $16, so a 10s1p A123 pack is going to cost you in the region of $132, give or take. This gives the following cost breakdown: Castle Creations ESC $210 E-Flite 110 Motor $170 1 12s1p A123 Pack $132 2 FMA balancing 10 Amp chargers $220 Gel Cell Field Battery $250 50 Amp DC Power Supply $275 Switching Mode BEC $35 Total $1292 You'd need two FMA chargers because they can only handle 6 cells max. That way you'd split the 12s1p pack into two 6s1p packs, and charge them simultaneously. By the way, did you cut any holes in the bottom of your Yak fuselage for cooling? At 30C the battery would be running at rated capacity at full throttle, so it would need lots of cooling. This would help the motor as well.
