Zenoah starting problems
Tower Hobbies
Logged in as Guest
  Printable Version
RADIO STAND - RTF
Seller:  nna423
Details:   $19.99   |  10/12/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Helicopters >> RC Helicopter General Discussions >> Zenoah starting problems
Page: [1]
Login
Zenoah starting problems - 2/11/2003 10:15:57 PM
imtheone
Status: offline
I have a new z230 with a zenoah I got it to run for about 15 minutes first tank. now I get it to fire then dies right away I ajusted low needle to 1.1/4 turn and high to 1.1/2 and open them a little more still no good even put in a new Plug. I am useing Zenoah oil with 7 ounces per gallon of mix Any Ideas sure could use some Thanks Imtheone
[email]hueyp@qnis.net[/email]
       Post #: 1
Zenoah starting problems - 2/11/2003 10:17:28 PM
Furyflyer2
Status: offline
Could your choke inadvertently closing as it's running?
_____________________________
Paul G,
www.3dxhobbies.com
(in reply to imtheone)
       Post #: 2
Zenoah starting problems - 2/11/2003 11:19:24 PM
Malorie
Status: offline
Set your needles to 7/8 on the low and 1 1/4 on the high. Dry out the plug and try it again. Your needles are WAY to rich. With 7oz. per gallon you may need to go even a bit leaner (by a bit I mean maybe 1/16th turn or so). 7oz. per gallon is a bit much on the oil also. You can break it in on 6 and move to 5 or 4 after the first gallon or so.
Good Luck,
Malorie
Life's a journey not a detination.
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.578RCU1
