trec esc install in axe.
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> Helimax >> trec esc install in axe.
Page: [1]
Login
trec esc install in axe. - 3/1/2007 10:26:48 PM
bryon261
Status: offline
installing the 240 gyro in my axe, went with the trec esc. pretty straight forward except for the 3 wire plug that connects to the reciever. In the heli max install instuctions it tells you to remove the middle wire(red) from the plug to disable the bec. this esc does not have a bec. this plug would normally plug into the gyro direct per instructions provided. do i plug this trec esc plug following the helimax instuctions ? if yes, do i remove the red wire from the plug?.... anyone
       Post #: 1
RE: trec esc install in axe. - 3/1/2007 11:21:47 PM
sammy64
Status: offline
Yes.. on the gyro there are 2 different wires connections .. a female and a male .. plug the female into the RX per instructions and plug the ESC ( Remove the red wire ) and into the Gyro Male plug ( If you dont remove the red wire you will be supplying 2 different power sources ) . then hook up your tail motor to the ESC and stand back
(in reply to bryon261)
       Post #: 2
RE: trec esc install in axe. - 3/2/2007 12:54:18 AM
bryon261
Status: offline
thanks alot for everything , got the battery thing all straightened out ,now i can finish the installing the esc and fly, yeah.
(in reply to sammy64)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.234RCU5
