HELP Stalling problem rs4 evo
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> HPI Racing >> HPI On-Road >> HELP Stalling problem rs4 evo
Page: [1] 2   next >   >>
Login
HELP Stalling problem rs4 evo - 3/1/2007 11:06:12 PM
GC8
Status: offline
I just got my nitro rtr3 evo, so im a straight up noobie, i went through all the trouble shooting already and its still doing the same thing. So ok here is my problem my rc will start up but once its on it will go crazy for like 2 secounds without me touching the remote and then shut rite off, its got gas, glow plug is fully charged btw its a roto start. please help me out Thanks
       Post #: 1
RE: HELP Stalling problem rs4 evo - 3/1/2007 11:25:44 PM
iexion
Status: offline
you have ur carb open too much im guessing.. Try to set your Throttle servo so te engine has a closed carb, also make sure your radio gear is set so everything is neutral.
http://hpiracing.com/graphics/instr/n3ss/kn3_31.jpg << its kind of confusing but read thru it, it will give a better insight.
And if all the linkage is correct then you might need to lower your rpm with the IDLE screw
http://hpiracing.com/graphics/instr/n3ss/kn3_32.jpg
_____________________________
"All you read and Wear or see and Hear on TV Is a product Begging for your Fatas dirty Dollar So Shut up and... "
(in reply to GC8)
       Post #: 2
RE: HELP Stalling problem rs4 evo - 3/2/2007 12:03:11 AM
hpi apollo
Status: offline
www.rchobbies.org/cars_eng-tuning.htm that should help, if you dont feel like reading i dont care you will WANT to read this whole guidehttp
95% of statistics are made up on the spot
(in reply to iexion)
       Post #: 3
RE: HELP Stalling problem rs4 evo - 3/2/2007 1:37:29 AM
GC8
Status: offline
Thanks guys after a hour and a half of tunning its not stalling no more, but it spits alot of gas outta the muffler is that normal? also how do i know if your running rich or lean? Thanks
(in reply to hpi apollo)
       Post #: 4
RE: HELP Stalling problem rs4 evo - 3/2/2007 1:49:16 AM
jeremiah__brown
Status: offline
Make sure its smoking good enough so you can see a steady plume coming out of the tail pipe & it should be good. There will be some oil coming out of the tail pipe thats not fuel thats the oil that keeps the motor lubricated, its normal. If you want to check the engine temp. use a drop of water on the top of the head. If the drop sizzles & evaporates within 3 seconds the motor is too hot " too lean". When the motor is running at the right temp. the water drop will take 5 to 8 seconds to dry up. Good luck.
(in reply to GC8)
       Post #: 5
RE: HELP Stalling problem rs4 evo - 3/2/2007 3:33:00 AM
iexion
Status: offline
Also, If u dont have any already, Go out and by some "after run oil". you can get this stuff at your local hobbyshop for $2-3 After your doing running your car, make sure theres no gas left in the engine then put around 5-8 drops in the carb and use the roto start to lube the engine, the after run oil will help keep your engine lasting longer and keep anything inside from rusting. What i do is take out the glow plug and put extra inside the engine its self. U dont have to do that step but its just some extra insurance for your engine. But i would take out the glow plug when u put the oil in the carb . It just makes it easyer to lube the engine.
It seem (for me anyways) that after run oil makes it easier to start up next time i want to drive my car
(in reply to jeremiah__brown)
       Post #: 6
RE: HELP Stalling problem rs4 evo - 3/2/2007 3:59:17 AM
jonsmilez
Status: offline
i didnt read 2 much of the forum, i kinda skimmed through.. but i didnt see anybuddytalk abotu batteries.. and when u say go crazy... was it the servos going crazy? like ur sterring and throttle rods?... cuz that would be ur batteries, just happened 2 me.. then i ordered a hump pack(a hump pack is a rechargable battery cell and it also has more power then 4 AA, its basicaly like 5 AA so instead of getting 4.8V from 4 AA batteries u get 6V (most AA batteries has 1.2V), which supposebly makes a difference--i would assume so but i havent recieved the hump pack in the mail yet... let us know what the problem is.. and good luck.. if u still cant figure it out remember local hobby stores are almost happy 2 hepl u out, and they usually sont charge that much... g luck bro
Past/Present: [TL-01] [Micro RS4] [RS4 Evo [XXX-T] [Firestorm 3.0]
Future: [Baja SS]
       Post #: 7
RE: HELP Stalling problem rs4 evo - 3/2/2007 11:59:41 AM
GC8
Status: offline
Thanks guys, i forgot to mention that when i start up the car it wont idle, the wheels will just spin until i turn it off, and i just put new batteries in the remote and the car.
(in reply to jonsmilez)
       Post #: 8
RE: HELP Stalling problem rs4 evo - 3/2/2007 2:22:30 PM
iexion
Status: offline
Yea the engine needs to be "pre tuned" so u can break it in. Set the low speed to fully closed (clockwise) then open it 3 full turns (counter clockwise) u shouldnt have to tuch the high end needle. always run with the air filter on!
(in reply to GC8)
       Post #: 9
RE: HELP Stalling problem rs4 evo - 3/2/2007 6:51:10 PM
GC8
Status: offline
Ok ill try that agian, but does the smoke from the exhaust sting your eyes?
Update. Try that agian still the same wont work, anyone know whats up it seems like when i start it up its in gear and will keep on going till i force it to shut off. throttle and everything works except for the brakes.
< Message edited by GC8 -- 3/2/2007 7:52:08 PM >
       Post #: 10
RE: HELP Stalling problem rs4 evo - 3/2/2007 9:27:15 PM
hpi apollo
Status: offline
there are only a few things that cause ti to take off
-idle is too high
-clutch is damaged or dragging
-air leak causing engine to run lean and rev
-tuning is just lean
(in reply to GC8)
       Post #: 11
RE: HELP Stalling problem rs4 evo - 3/3/2007 1:07:23 AM
HeLLsGoD
Status: offline
Also check your carb opening + radio trims. Pop out your airfilter and it should have a 1mm gap on the carb at neutral and open up completely at full throttle and brakes should work 100%
- HPI RS4 - HPI sprint 2 -
Dream, Drive, Drift.
       Post #: 12
RE: HELP Stalling problem rs4 evo - 3/3/2007 1:25:38 AM
iexion
Status: offline
Might need to take it to your hobby shop, if all else fails
(in reply to HeLLsGoD)
       Post #: 13
RE: HELP Stalling problem rs4 evo - 3/3/2007 3:24:59 PM
GC8
Status: offline
I think i know the problem, how do you adjust the throttle servo? do i just do it from the controller?
       Post #: 14
RE: HELP Stalling problem rs4 evo - 3/3/2007 5:43:34 PM
iexion
Status: offline
Either that way or take off the hardware on the servo and start over. What i mean is once u have the servo gear off ( not the servo it self) turn on the the transmitter and the
